Glove Box
Old Sep 16, 2006 | 04:25 PM
aztc2007's Avatar
Default Glove Box
what the hell is that button that says "set" inside the glovebox on the tc and what does it do?
Old Sep 16, 2006 | 07:11 PM
hatchinprogress's Avatar
bump
Old Sep 16, 2006 | 07:19 PM
Nick06tC's Avatar
its for setting you tire pressure sensor.
aandf1978's Avatar
tire pressure monitor, read your manual for more
Old Sep 16, 2006 | 08:02 PM
paul34's Avatar
It's to set your level of awesomeness
Old Sep 16, 2006 | 08:11 PM
jwaggz82's Avatar
make sure all your tires are set to 32 and hold it in for 10seconds. I had my tires set to the specs on the door and one of them dropped 1lb and caused the light to keep going on - my best advice is to do 32 all around and you are set.
Old Sep 16, 2006 | 08:28 PM
Somnambulated's Avatar
I've been pressing it for like half an hour and nothing's happening. Maybe you have to press it in rapid succession.
Yeah, it's the tire pressure sensor reset. I had to push mine after a blew a tire. Even though the tire pressure sensor didn't even show up until I was riding on a rim.
Which reminds me, I need to have the dealership check that.
Old Sep 16, 2006 | 09:29 PM
chazm's Avatar
So this isn't automatically set from the factory or dealer at 32psi?
Old Sep 16, 2006 | 09:34 PM
eLpReSiDeNtE's Avatar
tC squad
thats the "dust honda's" button....press dat when ur at a lite wit a civic and u'll see.....muuhhaaaahhahahhahaha
jwaggz82's Avatar
look inside your drivers door - it says i think to set the either the front or back to 29 and the other to 32
Old Sep 18, 2006 | 02:07 AM
JerseyGeorge's Avatar
ejector seat button
Old Sep 18, 2006 | 02:25 AM
BSP07tC's Avatar
It depends on the year how the car measures the pressure difference. On the 05-06 it is a different system. It only measures rotational difference. If it notices a difference in the rotational speed of any of the tires it will trigger the light. If all of the tires lose air at the same time it will not notice a difference in rotational speed. On the 07 it is an actual pressure sensor that notices a drop in individual tire pressure.
Old Sep 18, 2006 | 02:55 AM
jwaggz82's Avatar
nice post - i had no clue.
Old Sep 18, 2006 | 09:22 PM
SquallLHeart's Avatar
yes.. '07's have an entirely different ecu along with tire pressure monitoring
make sure when you change rims, that you remove the sensors from your old wheels and transfer them into the new one. otherwise you'll have a very unhappy car.
Old Sep 18, 2006 | 10:28 PM
jetlounge's Avatar
'05 models are different than '06 and up
...because the 06 and later have the steering wheel controls.
You have to hold down VOLUME DOWN while pressing the SET BUTTON in the glovebox. If your arms don't reach, try with your big toe on your right foot.
Put the key in the ACC position, then Press that combo 3 times and you get infinite life and all weapons.
airmankevin1
Nov 17, 2015 05:44 AM
Schmohey
Oct 4, 2015 02:53 PM
user9430961
Sep 24, 2015 01:09 PM
prescottn
Sep 22, 2015 01:30 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
