Glove Box
make sure all your tires are set to 32 and hold it in for 10seconds. I had my tires set to the specs on the door and one of them dropped 1lb and caused the light to keep going on - my best advice is to do 32 all around and you are set.
Originally Posted by paul34
It's to set your level of awesomeness
Yeah, it's the tire pressure sensor reset. I had to push mine after a blew a tire. Even though the tire pressure sensor didn't even show up until I was riding on a rim.
Which reminds me, I need to have the dealership check that.
It depends on the year how the car measures the pressure difference. On the 05-06 it is a different system. It only measures rotational difference. If it notices a difference in the rotational speed of any of the tires it will trigger the light. If all of the tires lose air at the same time it will not notice a difference in rotational speed. On the 07 it is an actual pressure sensor that notices a drop in individual tire pressure.
yes.. '07's have an entirely different ecu along with tire pressure monitoring
make sure when you change rims, that you remove the sensors from your old wheels and transfer them into the new one. otherwise you'll have a very unhappy car.
'05 models are different than '06 and up
...because the 06 and later have the steering wheel controls.
You have to hold down VOLUME DOWN while pressing the SET BUTTON in the glovebox. If your arms don't reach, try with your big toe on your right foot.
Put the key in the ACC position, then Press that combo 3 times and you get infinite life and all weapons.
airmankevin1
Nov 17, 2015 05:44 AM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
