Where's the Oil Pressure Sender Located on the xB engine?
Old Oct 17, 2006 | 10:31 AM
BPG's Avatar
BPG
Default Where's the Oil Pressure Sender Located on the xB engine?
I'm in the process of installing VDO Vision Gauges in my xB. I'll end up having a total of 7 gauges. 3 are located directly to the left of the instrument (Water Temp, Vacuum and EGT) and 4 will be installed on an Autometer Pillar Pod (Oil Pressure, Oil Temp, Analog Clock and Outside Temp) Where is the stock Oil pressure sender/switch located on the xB engine? If you have pictures, Please post!
Old Oct 17, 2006 | 01:18 PM
ProshopXB's Avatar
There is an oil sensor on the front of the engine.. it's is a couple of inches above the oil filter and a couple of inches below the plastic intake manifold.. Sorry no pics of it thou... Mine is used for my oil feed line for my turbo, you can't miss it... it has a plug with one wire. But it will require you to remove the plastic shroud under the car to get to it and I would recomend taking the bumper off for even easier acess to it.
Old Oct 17, 2006 | 01:21 PM
jallamas's Avatar
Its dead center under the intake manifold, it has 1/8 NPT threads and it has a green wire with a gray connector going to it.
John
Old Oct 17, 2006 | 01:26 PM
ProshopXB's Avatar
John
Damnnnnnn.... good call Atleast some one paid attention to the colors of it.. I sure didnt..
Old Oct 17, 2006 | 01:44 PM
jallamas's Avatar
Thx ProshopXB!
Old Oct 22, 2006 | 11:35 PM
islandromeo81's Avatar
here you go if you still need help
https://www.scionlife.com/forums/vie...393&highlight=
Old Oct 23, 2006 | 12:04 AM
jallamas's Avatar
^^^^^^Good job! Thats great info!
John
06ScionTc5sp1
9
Oct 16, 2020 01:18 AM
Col168c
27
Apr 9, 2020 10:48 PM
my06tc
Jun 25, 2015 12:18 AM
xxmanrd92xx
11
Feb 4, 2015 01:40 AM
eric_m
79
Mar 17, 2013 12:21 AM
