Removing OEM Pedestal Spoiler?
Old Dec 12, 2006 | 05:40 PM
ryphlex's Avatar
Default Removing OEM Pedestal Spoiler?
I'm trying to figure out how to remove it because I'm planning
on selling it soon for a different spoiler.
I'm not too sure on what's holding it down so if anyone could help me
out on this subject, it would be greattttttly appreciated.
Thanks!
Old Dec 12, 2006 | 05:57 PM
Yanki01's Avatar
you'll find holes in your hatch! open the hatch and remove that back piece, you should be able to get the bolts from there.
chrischoi's Avatar
take off the plastic and undrill the bolts.
Old Dec 12, 2006 | 06:41 PM
SquallLHeart's Avatar
undrill? more unscrew.... nuts.. not bolt...
but 4 nuts... and double-sided tape holds the spoiler down..
and yes... you'll have 4 holes.
Old Dec 12, 2006 | 07:05 PM
JQ's Avatar
JQ
^----agreed!
you will have to unscrew 4 hex bolts. Use a 10mm ratchet with an extension. After removing the 4 nuts you will have to pry the spoiler off of the hatch. This is being held on by some 3m type double sided tape.
As for the holes that are left you will have 4 - 3/8" inch holes to worry about covering up or using for a new spoiler.
Good Luck
Old Dec 12, 2006 | 07:35 PM
ryphlex's Avatar
Hmm.
What are possible ways to fill these holes in?
I'm buying the Viniati V-Spoiler and I'm not sure if this spoiler
directly installs into these 4 holes.
Old Dec 12, 2006 | 08:19 PM
it won't... but it might cover them up.
fill hole? bondo.
Old Dec 12, 2006 | 09:09 PM
TANTALIZEDMIND's Avatar
Scion Tuners
fill hole? bondo.
[Shot you this in a PM also.]
I want to do the same thing. i hate teh pedestal. I'm not sure what exactly to look for on their website to order for filling the wholes. Once they filled I'll take FM touch-up paint and coat them.
Then... new spoiler! Thanks.
I don't know where EXACTLY to look once I get to here.
http://www.bondo-online.com/catalog_browse.asp
I'm guessing fillers, but theres 5 categories, then sub-catagories.
Old Dec 12, 2006 | 09:12 PM
chrischoi's Avatar
yeah. i was multi tasking and got it mixed up. i was thinking about them drilling the holes. they are suppose to drill holes into the structure support... but sometimes, some places... are lazy and drill at a angle to save time.
Old Dec 12, 2006 | 09:19 PM
... structure support? angle?
i'm not exactly what you're talking about... i've installed this spoiler a few times...
Old Dec 12, 2006 | 09:23 PM
chrischoi's Avatar
you k now when your in cold weather and the car is covered in condensation... you see the lines on the hatch and hood... the beams that support it... you are supposed to drill through the whole supporting part of the hood. sometimes techs and differenent dealerships dont do that... and they drill around the whole support.
Old Dec 12, 2006 | 09:32 PM
jasper's Avatar
hey dude, this is about taking off the factory spoiler / wing, what's wrong with the lines on the hood?
Old Dec 12, 2006 | 09:33 PM
uhm... the pedestal spoiler...
the hatch itself has supports.. but they do not however have anything to do with supporting the spoiler.
you need to drill into them so you can get to the bolt so that you can install the nut. who cares where the hole is?? as long as they can install the nuts..
have you seen the installation instructions? or have seen one installed in person?
Old Dec 12, 2006 | 09:42 PM
chrischoi's Avatar
i'm not trying to argue with you trung. some people drill holes around the supports on the hatch.... because it's easier to drill at an angle and avoid the supports... then to drill through them... it was off topic.
Old Dec 13, 2006 | 02:52 AM
jasper's Avatar
well, i still have no idea what are you talking about chrischoi...
YooItsJay
Dec 2, 2015 08:13 AM
Kata
Mar 2, 2015 10:46 PM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 5, 2015 06:09 PM
kdepew
Jan 5, 2015 12:42 AM
Opr8r
20
Feb 25, 2004 11:29 PM
