General Tech and DIY Info for Any Scion
Seat Belt Warning (Disable Beeping)
Old Dec 7, 2005 | 01:48 PM
  #41
System_Operator's Avatar
up up down down left right left right B A select start
^ right there baby...
Old Dec 8, 2005 | 06:39 PM
  #42
adog4ya's Avatar
Default Just wanted to say thanks for the tip.
I just traded my Audi in on a TC and one of the first things that annoyed me was the belt warning. The initial warning is ok, but then it should shut off. I was glad to see there was a fix for this.
Thanks again,
Adam (adog4ya)
06 TC CSM
Old Dec 8, 2005 | 07:57 PM
  #43
nero_tC's Avatar
Originally Posted by RS2_0
Originally Posted by Jowie
Originally Posted by JW2
up up down down left right a b a b a start select
I thought it was UP UP DOWN DOWN LEFT RIGHT LEFT RIGHT B A B A START?
Isn't that the code to get full health on TTMN on gameboy like a long time ago? To get a full health while shredder is giving you the 1 fisted love slap.
i think that was contra...
Old Dec 9, 2005 | 02:52 AM
  #44
ROBOTCRANKIT's Avatar
Scion Driven Girls
Originally Posted by cubaricantC
theres actually a lot less steps than that though,
turn ign. to on position
switch to odo view press and hold for 10 secs
while still holding, buckle drivers belt
hit odo button to toggle b-on or b-off
thats it, you're done, thats how I do it on mine and works every time
How many times would you have to turn off the beep alarm for the seatbelts?
...or do you like to turn them on and off just for fun?
Old Dec 9, 2005 | 03:10 AM
  #45
06_t_cizzle's Avatar
Concept in Motion Crew
nice!!
Old Jan 5, 2006 | 08:04 PM
  #46
NaStY's Avatar
i did it fist try no prblem.
  #47
NaStY's Avatar
i did it first try no prblem.
Old Jan 7, 2006 | 12:56 AM
  #48
rampage1003's Avatar
seeing as how i just bought a original nes do you guys have any other codes i could use
Old Jan 7, 2006 | 05:49 PM
  #49
SciontCya's Avatar
Big Sky Scion
Nice. I have a long drive in my parking garage, and I always feel the need to take off my belt in there...this will save my sanity.
Scott
Old Jan 7, 2006 | 05:54 PM
  #50
engifineer's Avatar
On mine you can leave the brake out and only buckle one seat belt and get the b off. But, no matter which method you use (the easy one or the one posted here) it doesnt do squat (other than say b off) on mine. The beep is still there.
And yes, to all you people just ready to pounce and start issues, I ALWAYS wear mine unless I am driving through the parking lot at my apartments to pick up packages (which is quite often with the various little projects I do for people). And it is annoying as hell to listen to that beep or have to buckle/unbuckle for just that. I dont need a beep the rest of the time (it is just annoying) to remind me to wear them.
Old Jan 7, 2006 | 06:03 PM
  #51
SciontCya's Avatar
Big Sky Scion
^^^ Odd. When you get to b off, turn the key off. Does that work?
Anyhoo - I always wear my belt too - the ONLY time I don't is in the parking garage...
Scott
Old Jan 7, 2006 | 06:15 PM
  #52
engifineer's Avatar
Scott
Doesnt work either. As far as I can tell, the setting is ignored on mine. Its not that big of a deal though, just a minor annoyance.
Old Jan 7, 2006 | 06:22 PM
  #53
SciontCya's Avatar
Big Sky Scion
I'm sure you've tried everything at this point, but are you putting the key to on and not acc?
Did you make sure to toggle through to ODO a couple of times? All these things seem really finicky.
Scott
Old Jan 7, 2006 | 09:53 PM
  #54
Kathryn's Avatar
good post. i hated that beep when i had my stock seats.
Old Jan 7, 2006 | 10:15 PM
  #55
blimey's Avatar
Tried this on my xB didn't seem to work
Old Jan 8, 2006 | 03:53 AM
  #56
phungy's Avatar
The beeping is annoying but I still put on my seatbelt.
Old Jan 29, 2006 | 06:29 PM
  #57
june's Avatar
Took my car to the dealer ship to get the sound from the seat belt and they could not get it to go off. That was three guys that work for sicon.
Old Jan 29, 2006 | 11:06 PM
  #58
SciontCya's Avatar
Big Sky Scion
June, Most of the people at SCION didn't know anything about the tricks for that and the radio - I wouldn't stop trying due to them...
Scott
Old Jan 30, 2006 | 01:17 PM
  #59
icdedppl's Avatar
ok, first, the instructions aren't 100% accurate on this post. you do NOT have to plug in BOTH seatbelts to get this to work. just the driver's side seatbelt is fine. you can find my instructions here on the faq site: http://home.cfl.rr.com/icdedppl/faq.html#c6
and just to run through this again, this is REALLY easy to do:
1. turn key to "on" so where you would normally be able to listen to the radio. hit the trip button til ODO is displayed. once displayed, turn the key to "off" so that the radio is turned off.
2. turn the key back on to where the radio has power. WITHIN 6 seconds, press and HOLD DOWN the trip meter button for AT LEAST 10 seconds. count 1-one thousand, 2-one thousand, etc in your head and count up 12 to make sure.
3. WHILE YOU ARE STILL HOLDING DOWN THE TRIP BUTTON and AFTER the 12 seconds has passed, plug in your driver's side seat belt. you will see on the trip lcd display that it will say "b-OFF". your buzzer is now turned off and you can take the key out of the ignition.
4. to turn the buzzer back on, follow the procedure again.
sorry for this redunadant post, but people might be trying to plug in both seatbelts or missing a simple step, but this will work on all 2005-2006 scion tcs! not sure about xas or xbs...
Old Jan 30, 2006 | 05:41 PM
  #60
SciontCya's Avatar
Big Sky Scion
^^^ Very true. I used that method after the more complex one didn't work right away.
Scott
