We pride ourselves on being a welcoming community we are happy to see you here and we want to get you talking to us, start here by telling us about you and your Scion.
*PLEASE DO NOT POST TECHNICAL QUESTIONS IN THIS SECTION*
View Poll Results: What else could it be?
Unbalanced tires
0%
Transmission mounts (they were wrong)
0%
Wheel bearing/hub assembly(I'm an idiot)
0%
Cv joint
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
2009 Scion TC 5.0 series has front driver vibration
Old May 10, 2022 | 04:51 AM
JessicaCharrette's Avatar
Default 2009 Scion TC 5.0 series has front driver vibration
Hi, I'm new here but, need some help diagnosing an issue I'm having. I have a 5-speed manual and months ago I started noticing that when shifting hard or downshifting I'd get some clunking under the hood. Now, my first thought was "oh no, it's either transmission or motor mount!" Brought it to aamco to have them put it on the lift and check it all out. They said absolutely nothings wrong with it. They said I probably "wasn't shifting right" I've been driving for 15 years and learned how to drive in a ____ty 89' Corolla 5 spd manual that 2nd had gone out in. So I pride myself in being able to drive anything and I've actually only owned clutches besides one automatic bmw X3 only because they didn't have a manual option. I know how to drive a clutch. Anyways, now it's to the point that the driver's side what seams to be wheel is violently shaking and humming especially when I get up to 50-75 on the highway. It will completely stop if I turn the wheel slightly left but if I turn it even a little right it gets much louder. At low speeds like turning into the gas station or down a street it doesn't click or pop. So, I haven't suspected a cv joint. I was thinking wheel bearing. Jacked it up and tried to wobble side to side and up and down and it's perfectly tight both ways. Got new tires since I noticed that particular tire was worn uneven on the tread. Didn't help. I do know the previous owner did some upgrades to the suspension, got drilled/slotted rotors, sway bars, cold air intake, carbon fiber hood, and after market rims. If that helps. What else could it be? I'm very stressed about this and need to fix it ASAP. Any ideas would be greatly appreciated!
Old May 10, 2022 | 06:52 AM
Jon's Avatar
Jon
Moderator
Moderator
Great to hear from you JessicaCharrette! Welcome
Nicole412
Mar 23, 2015 06:26 PM
13edge
11
Oct 16, 2012 04:45 AM
Fisqual
Aug 17, 2011 02:59 AM
Tranman
Aug 16, 2006 02:04 AM
zx8DragoN8xz
Dec 27, 2004 04:33 AM
