Dustless Brake Pads???
These r supposto be really good
heres the link
http://www.mossmini.com/Shop/ViewPro...eIndexID=34834
i think thell fit the XB too!
heres the link
heres the link
heres the link
you can always get that brake dust shield thing. just extra crap to put on but it'll keep the wheels clean.
ugh... http://www.qualitysmart.com/products...leenwheels.htm
it'll make your rims look like hubcaps but it'll keep them clean
Guest
Posts: n/a
if your gettin a lot of brake dust, maybe you should change your driving habits. Brake dust only appears when you BRAKE a lot!! Time to stop beating everyone to the stoplight and learn some safety habits when braking. You don;t want to mess up your brakes this early in the game. :?
Try Looking into Ceramic pads! Not only are they supos to be cleaner they handle the heat better and I have herd the actuly work better! I have actuly found them to be caried at most auto part stores! Oh the down side is they a a bit more expensive!!
Was looking at getting a set of porterfields for one of our trac cars, I've had good luck with them on the track in the past.
One thing to keep in mind also though is that generally the pads that offer better bite in stopping power produce more dust. Compromises are made in brake pad construction that may make a substantial difference in braking ability, dust, noise, fade, "working" operating temperature, etc. Nothing is free in this department.
Mike
Mike
Ctech is right you wont get rid of the dust just limit the amout you have to clean! I dont know if they work or if they are even on the market but some shields you put on the insie of the wheel between the brake were sold and it kept the brake dust off the wheels but im not sure if they can be obtained or are made any more!
Guest
Posts: n/a
Ceramic Pads - try Napa Auto Parts. My experience is they're a lot more expensive, but they cut down on the dust. My vehicle now (not a Scion) is very heavy and the OEM pads get too hot and glaze over and then start squealing. They make a lot of dust, too. My silver wheels look brownish/black by the end of 7 days. Ceramic pads are nearly 3x as expensive as regular pads.
Once I get into the xB, though, I'll be putting on ceramics immediately.
The only bummer with ceramic pads is the harder compound eats through rotors a bit quicker. Buddy of mine has Lincoln LS which comes standard with ceramic pads and aluminum calipers....supposedly he found the LS goes through brake jobs a bit faster than normal pads, but it isn't a dramatic difference UNLESS you are hard on your brakes.
I have tried the EBC Green Stuff and the Mintex pads on my old Focus. I prefered the EBC's by far. Better initial bite, less brake fade, and hardly any dust on the wheels. I abused the ____ out of those brakes autocrossing and I would recommend them to anyone looking for a good street pad.
Klashan
Sep 24, 2015 12:39 PM
