Low RPM Pinging
Old Oct 24, 2008 | 06:15 PM
Beers's Avatar
Default Low RPM Pinging
i have a 05 XB with 60,000 miles on it and i have always used premium gas in it yet it makes the pinging like i was using shabby low octane gas. it always happens between 1500 and 2500 rpm. i have also been seeing my mpg go down since this has been happening. any ideas on what it could be? i searched on here and couldnt find anything similar to what i am experiencing. any links or advice would help.
thanks
Old Oct 24, 2008 | 06:22 PM
equinox2355's Avatar
First question would be why you are using premium.
Old Oct 24, 2008 | 06:30 PM
Beers's Avatar
its only two dollars extra per tank
Old Oct 24, 2008 | 06:34 PM
CHPRBOX8's Avatar
that is just a normal sound on the 4cly engine my xb has been making that noise since new just something that you have to get used to go get a fuel system cleaner and you mpg's should go back up. plus right now there is more ethonal in the gas for winter and that is going to cause the mpg drop
Old Oct 24, 2008 | 07:24 PM
Beers's Avatar
mine just started making the pinging about a month ago but i will fully try some fuel system cleaner again. i used the prolong when it first started making the noise and it didnt quite cure it, it just went away for a little.
could my valve timing be off?
Old Oct 24, 2008 | 08:22 PM
CHPRBOX8's Avatar
i dont know about that but i would stop using that prolong it dose not help check out something from amsoil they are better
Old Oct 24, 2008 | 08:33 PM
Beers's Avatar
ill try that for sure. thanks!
k1114
43
Mar 1, 2023 03:08 AM
Greg S
Jul 21, 2016 07:28 PM
Fisqual
Sep 22, 2015 05:51 AM
cid_mcdp
Jan 5, 2015 02:45 PM
jackmott
Feb 5, 2004 06:33 PM
