P0500 CEL Code.
Old Nov 25, 2013 | 11:18 PM
Chrisb319's Avatar
Default P0500 CEL Code.
My CEL code came on today coming home from work. I had the guy at autozone scan it, it came up as P0500 he said it was probably a speed sensor. My speedometer works just like it has from day one. My cruise control still works.I have a pioneer D3 installed that I know is connected to the speedometer wire but that has been installed for almost 5yrs now. Anyone know how to further investigate the problem.
it's a 2007 Scion tC, automatic.
Old Nov 26, 2013 | 08:24 PM
jct's Avatar
jct
http://www.obd-codes.com/p0500
Vehicle Speed Sensor Malfunction What does that mean? Basically this means that the vehicle's speed as read by the Vehicle Speed Sensor (VSS) is not working properly. Symptoms Symptoms of a P0500 DTC may include: loss of anti-lock brakes the "anti-lock" or "brake" warning lamps on the dash may be lit the speedometer or odometer may not work properly (or at all) your vehicle's RPM limiter may be decreased the shifting of an automatic transmission may become erratic other symptoms may also be present Causes A code P0500 may mean that one or more of the following has happened: The Vehicle Speed Sensor (VSS) is not reading (functioning) properly There is a broken/frayed wire leading to the vehicle speed sensor The vehicle's PCM is not correctly configured for the actual tire size on the vehicle Possible Solutions The simplest thing to do is to reset the code and see if it comes back. Next, check all wiring and connectors that lead to the speed sensor. The location of the sensor depends on your vehicle. The sensor could be on the rear axle, transmission, or perhaps the wheel hub (brake) assembly. If the wiring and connectors are OK, then check the voltage at the speed sensor. Again, the exact procedure wil depend on your make and model of vehicle. If everything looks OK, replace the sensor.
Read more at: http://www.obd-codes.com/p0500
Copyright © OBD-Codes.com
MeDizzy
Oct 8, 2015 03:31 PM
Ways808
Aug 2, 2015 08:13 PM
mw1957
Jul 28, 2015 06:04 AM
mw1957
Jul 28, 2015 05:31 AM
RacerZack
12
Apr 11, 2005 11:30 PM
