Question about synthetic oil
Old Dec 10, 2005 | 06:27 AM
stuUNGAR's Avatar
Default Question about synthetic oil
I'm going to change to synthetic oil this weekend and apparently once you go to synthetic, you can't go back, right? But can you switch between brands? Basically I have the option between Mobil 1 and Royal Purple? What should I choose?
Old Dec 10, 2005 | 07:23 AM
Tomas's Avatar
Admin Emeritus
Actually you CAN go back, but why would you want to?
All the current synthetics I'm aware of have no problem with changing brands or moving from syn to regular and back.
Makes most sense, though, to pick a brand and type and stick to it...
Old Dec 10, 2005 | 08:45 AM
killerxromances's Avatar
Default Re: Question about synthetic oil
Mobil 1 is what i run.
You technically can go back to regular oil, but 1. why would you? and 2. if you switched it up a lot, i would imagine problems would occur. Obviously best thing to do is if you switch to synthetic stay with synthetic.
Cya
Old Dec 10, 2005 | 08:50 AM
magicmanjk808's Avatar
you can switch brands, but i would stick with one. maybe switch until you find one that you like and stick with that.
Old Dec 10, 2005 | 08:53 AM
Exactly.
Cya
Old Dec 10, 2005 | 11:08 AM
Sciond's Avatar
Royal Purple..0W30 ..I would use 0W30 in whatever you choose as it changes viscocity according to temp
Old Dec 13, 2005 | 06:19 PM
markbvt's Avatar
Umm... any multi-viscosity oil does that...
It would be much safer to stick with the 5W30 recommended by Scion. 0W30 might get too liquid at high temps and fail to protect your engine properly.
--mark
06ScionTc5sp1
9
Oct 16, 2020 01:18 AM
bootlgr
Jan 26, 2016 01:22 AM
Scionxa180
Mar 13, 2015 04:39 AM
yanges
14
Jan 15, 2004 04:43 AM
smilygo
Dec 30, 2003 07:45 PM
