tC low buzzing noise when shifting
Often times when I shift (seems more prone just after the car has been started) I get a low/deep rumble/buzzing noise right after the shift is complete. It's about a second after I re-engage the clutch bzzzzZZZZZzzzzz... Seems as if it's coming from the front right of the car.
What is this? Any ideas? Should I be afraid?.... Very afraid?.... Or is it just nothing ;)
No, my first car was a manual. I never really had anyone show me how to drive one though. It's not about to stall if that's what you're saying. It doesn't shake or anything. :-/
Originally Posted by eeyoredragon
An update: It only happens in third gear, and when I'm very slowly accelerating. I typically shift at 3krpm from second into third when I'm going that slow.
I'm a car n00b. Have some books arriving to help educate me, but they've not arrived yet.
I'm about to go wash my car, so I'll let you know. In advance, assuming that fixes it, what's the reasoning behind that? What's actually making the noise and why? If you don't mind taking the time of course
I'm a car n00b. Have some books arriving to help educate me, but they've not arrived yet.Senior Member
Team Sushi
You mentioned that it mostly happens when you just start the car. . . in the manual it tells you flat out to not let the engine sit at low revs or use high gears at low speeds(same thing) . . especially when accelerating. You shouldn't be racing the engine either, but you should shift at 3500 or 4000. I think 3000 is a bit low for a 4cyl car.
It's just as bad as letting your car idle for awhile after start up. . . I believe it's in the manual as well, but I'm not sure about that. You want everything to heat up in a nice and uniform fashion, in addition to getting all the fluids to move around.
Raiders757
Apr 14, 2015 10:26 PM
TheTripleC
Jan 4, 2015 06:46 PM
