Two-prong Question -- Interior & Exterior!
In my semi-buzzed state of mind the other night, I threw a piece of Chic-let out the window, but through the power of wind sheer and driver idiocy, it landed in my backseat instead
I pulled out some of it, but can any of you recommend a good cloth cleaner/remover?
And my other question was, I got that annoying dealer name sticker plate placed on the hatch. I should have probably attempted to remove it early when it was still not completely dry, but I didn't have time. Has anyone used a product for such a task?
Thanks
Thanks
I would think if you can get the gum really cold it should pick off easily, (maybe lay an icecube in a ziplock baggy on it for a while) I know it worked on carpet in my house a couple of times. As for the sticker (WHY do they do that!?!) I would heat it up a bit with a hair dryer (low or medium), Slowly and Carefully peel the label off, then wax the area. I hope these help you out. Good Luck
bootlgr
Jan 26, 2016 01:22 AM
viciouzgamer
Mar 27, 2015 12:16 AM
