What is this blue light It is always on
Originally Posted by PandaIst
That light indicates that your engine is still cold and is warming up. Once your engine is warm it should go away.
since it is always on...
thanks Matt
i dont know. you probably dont need to unless you're doing fairly long trips where the RPMs are high. I live in Nebraska (which has probably about the same temperature if not higher than Wisconsin) and mine doesnt turn off for quite some time. It's cold out and it will take longer to warm up unless you push it. thats just my .02. i wouldnt worry about it immediately. now if it was overheating then i would be worried. hope this can put your worries down a little bit.
thanks,
Matt
It shouldn't stay on once the car is up to normal operating temp. Mine goes out within a few blocks of home, of course it may be a little warmer here in Cali.
Normally, when the light is on, the car won't shift into O/D. If yours is staying on and keeping it out of O/D, it'll cost you some serious MPG...
From my experience and observations (and reading the owners manual) the blue light is the "cold coolant temperature indicator" for the radiator coolant. It is there to let you know that the engine is not yet up to operating temperature and that you should wait until you turn on the heater or you'll get cold air. It also means that you probably shouldn't drive like a maniac or your gas millage will suffer.
On my xB with an automatic, the computer actually prevents the car from shifting into 4th gear until the light goes out. It seems to be designed that way to help warm up the engine quicker. It is my theory that such a design will prevent cold engine sluggishness and reduce pollution by bring the catalytic converter up to its operating temperature more quickly.
It seems odd, but it works. I live in NY and the car only takes about 4 minutes to warm up when driving.
:D
:D
Those of you who said it is a "cold coolant" sensor light, are correct. But this does not mean your engine will be damaged from high RPMs. Do not get coolant temp and oil temp confused, as they are not the same thing. My suggestion is to go back to the dealer and ask them if this is a common problem in your area. I've grew up in florida, where coolant temperatures are always warm, even if your thermostat is stuck open. I've been here in WA for about 4 years now, and needless to say it takes a much longer time for the coolant to heat up. What did I do? I added "water wetter" and made a bracket that blocks off 1/2 of the radiator (I'm sure you big rig drivers know what this is) Basically it lowers the airflow through the radiator and causes less heat exchange, thus allowing your car to reach optimal temeratures even in sub freezing temps.
Had a similar problem (and did the same things) on my old Subaru.
Sounds like the thermostat is stuck open and is not allowing the engine to come up to temperature.
Better take it in to the shop.
Back in 1961 when in the Air Force in Germany an acquaintance had an accessory added to his Mercedes. It was a window blind type of thing mounted in front of the radiator. Controlled by a chain affair from the dashboard. It was installed at a dealership. I have since looked for such a thing in the aftermarket and never found one. So sad as this was one of the practical add ons that I have seen.
not to worry guy, this light will go out after the car reaches operating temperature. don't take it to Toyota unlessit NEVER goes out after 5-8minutes or so. just to save a trip to Toyota and be embarssised (man i cant spell for S*it!)
jaspercanda
Dec 28, 2014 10:09 AM
IceBox
9
Nov 4, 2003 04:35 AM
