tC: 2005 tC Engine & Manual Transmission
I am selling a 2005 Scion tC engine as a Parts Engine. It has been sitting since 2010. The head bolts would not tighten since I did not use new head bolts and it does not have an idle pully. What it does have is the following;
Engine (Block and head assembled)
Header
New Never Installed Radiator
Manual Transmission
Shift Linkage
1 Set of Front Axles
1 Set of Rotors
Gas Pedel from '05 tC
ECU
Engine Wiring Harness
Dash wiring harness (the only thing fully connected is the gas pedel wiring. The rest were cut but I went back for the whole thing)
Also got a Stock 2007 Scion tC Muffler w/ 29,XXX Miles
I'll let the engine go for 300 and transmission for 200.
Everything is negotiable.
You must pick up items.
I'm in Phoenix, AZ
Header
Manual Transmission
Shift Linkage
1 Set of Rotors
ECU
I'm in Phoenix, AZ
evolving_machine
Oct 21, 2023 01:16 PM
