Rear Garnish Help
Hey does anyone know how to remove the rear garnish because I need to replace mine but I'm not sure wether I just unscrew the screws on the liftgate handle or what. Any help is appreciated thanks!
are you talking about the part above the plate?i assume...if so you have to take it off from inside the hatch,,,unscrew the the plate lights then pop off the panel from inside you will see the screw's then presto it will fall in your hands ill see ifi can find the tech guide for it..
yeah. you need to take off the interior panels of the hatch, and it'll be easier to access the nuts you'll need to remove from behind it.
uhm.. where are you located..?
DaBlackBox
134
Apr 10, 2022 02:04 PM
airmankevin1
Feb 14, 2018 01:23 PM
