Dr. Isotope Gear shifter
Does anyone have the Dr. Isotope short shifter? I have the 50% reduction and 1 1/2" drop. It doesn't feel quite right and I wanted to see someone else's if they have this mod done.
It feels good, clicks into place nicely, it just doesn't want to go into 1st or 2nd easily.
Dredger:
–noun
1. Also called dredging machine. any of various powerful machines for dredging up or removing earth, as from the bottom of a river, by means of a scoop, a series of buckets, a suction pipe, or the like.
you need 10mm, 12mm and 13mm, phillips #2, hammer, and elbow grease. Also, a tool to get the end socket cap off the bottom of the stock shifter. (we used a wrench and a hammer).
I don't know about a dredger though.
–noun
http://doctorisotope.com/index.php?o...d=26&Itemid=25
Sorry for the double post, but the dremmel is attached to the drill.
Paul. I have an extremely hard time downshifting into second gear if i am going over 20 mph... even though second carries you all the way to 45mph @ about 6000rpms (not even redline).. so you'd think around 30-35mph @ about 4500rpms that you would be able to downshift right?
I dunno.. I just have the stock shifter, but to counter my frustration with not being able to get into second above 20 mph (without having to pause a couple second and slowly press into second) I've begun double clutching for second gear now. I'm fine with doing it, and I've actually got fairly good at it, so when you want some hard acceleration out of a turn or some easier engine braking, then I'd say try doing that.
Yea, cory who was sitting passenger took off the washer with a flathead. It scratches it up a bit but it's no big deal.
edit: You get a replacement washer as part of the dr. isotope kit so you can beat the hell out of it like cory did. RIP stock washer.
I got it and installed myself, it wasn't too hard. I LOVE it. Even my friends love it and they are jealous of it, haha. They always want to drive my car. It's fine to me, it's just hard to get into reverse sometimes, but not too bad.
WRX1316_TcVicent
Jul 22, 2021 06:06 PM
