Regional - Southeast FL, GA
having problems with cathodes -- miami area
Old Feb 18, 2008 | 05:25 PM
VIP_tC08's Avatar
Default having problems with cathodes -- miami area
i have some oznium cold cathodes installed in my footwells which i had done by a local guy, well right now the passenger side is not turning on, i bought new tubes and a tranformer thinking that was the problem, but i tried swapping them out and still dont turn on...i have been trying to get the guy who did my install to check it out, but all i get are excuses that hes too busy..so if anyone does this or can recommend me someone that does i would greatly appreciate it..i will gladly pay them for their time...and please do not recommend ala "fishingexpert87", because he is the one who did my install and am having a problem for him to look at it..thank you
Old Feb 18, 2008 | 05:33 PM
randomsuper's Avatar
you might wanna change the title of the thread and state you are having problems with cathodes. i wqas thiniking you were looking for someone to swap out the led's in your dash or something. good luck.
Old Feb 18, 2008 | 06:13 PM
caveman's Avatar
1UP Crew
Do you know how they are hooked up?
To your fuse box then to a switch, etc.??
Old Feb 18, 2008 | 06:23 PM
VIP_tC08's Avatar
yes thats ecactly how its set up
Old Feb 18, 2008 | 06:24 PM
VIP_tC08's Avatar
no actually the battery terminal then the cathodes then to a switch..i believe
Old Feb 18, 2008 | 06:30 PM
caveman's Avatar
1UP Crew
Ok so power is running from the battery to the switch...from the switch to the transformer...?
Did you need to extend the wires off of the cathode in any way?
Ummm I would say to check ur wires make sure there are no loose connections, or make sure the wires are secure in the switch...
Or if you needed to extend the wires so that the cathode can connect to the transformer....try to reverse the wire because the cathode wires are polar sensitive...
Old Feb 18, 2008 | 06:37 PM
VIP_tC08's Avatar
i did all that, and still nothing but me not being very elicltrical knowing its pretty difficult..every other thing still works, the drivers side cathodes, the leds in the cup holders and air vents, just not the passenger cathodes
Old Feb 18, 2008 | 06:42 PM
caveman's Avatar
1UP Crew
And if you look at the tube, they arent broken..
Sorry it sounds like a stupid question, just tryin to eliminate every possiblity
Old Feb 18, 2008 | 06:51 PM
VIP_tC08's Avatar
no the tubes are fine, i even bought new ones and a new transformer just in case they were, but still mothing
Old Feb 18, 2008 | 10:30 PM
VIP_tC08's Avatar
never mind..it ended up being that the tubes were cracked, just real hard to tell..man these things are cheap, they cracked just by the vibration of the car, but its all resolved i found a shop that did a complete clean up and install of Varad LED tubes, boy are these bright and much more durable..all for $65
Old Feb 19, 2008 | 12:06 AM
caveman's Avatar
1UP Crew
O aight....glad u finally got it all worked out...
Old Feb 19, 2008 | 01:47 PM
you sure it was vibration? i had mine installed in my xa for over a year and the only time they broke were when they got kicked by a passenger. other than that, i never had a problem.
evolving_machine
Feb 27, 2015 09:53 PM
randode
44
Jun 29, 2004 04:19 PM
Opr8r
25
Jan 13, 2004 07:42 PM
Besk_one
Nov 17, 2003 09:28 PM
BlueBox
9
Sep 25, 2003 04:36 PM
