08 headlight TSX retrofit 56k beware
BTWm let me teach you another way to colormod these projectors after the washermod:
Step 1:
Get that metal stuff from a 16-18ga wire or just get some cardboard and cut it rectangularly as shown here. This is also called a cardboard spacer in case you wanna look it up on hidplanet
Step 2:
Put it on the right side of the projector bulb holder
Step 3:
so you can see, what i actually did was (and also because the camera is a 2mp cameraphone) i flipped the rectangular shaped "spacer" to show the back since it's white and will be seen perfectly fine placed on the bulb holder. I did this because the black spacer will hide underneath the black base of the bulb thus causing some confusion as to what's going on but anyways here it is:
Step 4:
Place the bulb into the bulb holder and secure it tightly, fire it up and you're good to go.
Disclaimer: srtriker_1818 is not responsable for any potential damage caused by the cardboard spacer or anything whatsoever to the projector, bulbs or ballasts igniter. Results may vary. If you're not comfortable modding your projectors, please it is advised to take it to a professional and have it done there.
Washer mod on tsx projectors will result in these(notice the flares):
Colormod to eliminate the flares will result in these:
Step 1:
Step 2:
Step 3:
Step 4:
I don't think that I am going to color mod mine, I like the sharpness better then all the color. I am coming up with a better way to mount the projectors also when I get my dremel I'll post the brackets that Im gonna make.
Originally Posted by faran_r87
hey megrog2, what are those that u used to mount the tsx projectors the headlight houseing
Stock projectors are wack, taking out the low beams is less fabrication work for me.
The stock projectors have horrible output compared to the tsx projectors. TSX is wider, brighter, and made for HID's. Aestics wise it may looks nice, but im going for better output.
The stock projectors are fine, yes I agree that the TSX are better, but you have the lights opened and you have an extra set of projectors. You might as well retrofit those into the high beams for even better functionality.
vi3tb0i09
Sep 23, 2015 08:32 PM
atlantaemail
Sep 20, 2015 02:03 AM
