Cheapo Projectors Fix time
Old Oct 18, 2006 | 04:19 AM
mFrosty's Avatar
Default Cheapo Projectors Fix time
Ok so I bought the projectors they offer on ebay, but I bought them through Viniati thinking that maybe they'd be better. Wrong! They fog up like no other. So what can I use to seal the puppies up better? Second, I was supposed to send out my second set of these to BlueBat because he's gonna make overlays but I had some issues and had to put it off. But tomorrow they'll be in the mail so soon we'll have smoked side markers and eyelid overlays for these headlights. Third, I'm going to bake them and fix the cutoff (which isn't all that bad) as well as maybe solder in superflux leds for the angel eyes. And finally I would really like to go HID but is that not possible with these headlights? The housing says not designed for HID but neither is the stock housing right? and people put HID's in those....any help would be great and thanks ahead of time.
Old Oct 18, 2006 | 04:24 AM
AgentRice's Avatar
link to the ones u bought? so i can see what ur workin with and try to figure out wats wrong
Old Oct 18, 2006 | 04:43 AM
mFrosty's Avatar
http://www.viniati.com/0506-scion-pr...k-p-13453.html
they loook like these.
http://cgi.ebay.com/ebaymotors/04-05...ayphotohosting
Old Oct 18, 2006 | 04:47 AM
AgentRice's Avatar
theres a thread on here were a guy took those apart and adjusted the projectors.
https://www.scionlife.com/forums/vie...ight=projector
check that out. and once u fix the beam.. re seal it. and do it GOOD!
Old Oct 18, 2006 | 05:21 AM
Hsua's Avatar
I think if you are going to bake the headlights apart, you might as well get some quality projectors and make them... not "cheapo" but practical projectors.
Old Oct 18, 2006 | 07:13 AM
mFrosty's Avatar
I wish I could afford to do that right now but I'm sure that's expensive and not practical since I already purchased aftermarket lights and what not...
I'm busy savin for the stage 0 zpi lol isn't everyone ....
Old Oct 18, 2006 | 07:39 AM
dp-_-'s Avatar
people still buy from zpi?
Old Oct 18, 2006 | 07:50 AM
mFrosty's Avatar
welcome to the forums....
Old Oct 18, 2006 | 12:15 PM
amanda776's Avatar
I am in the same exact situation except I bought mine off themodcity not viniati. It sucks when you dish out extra money thinking that you're gonna get a better product and in the end you get screwed. I don't know the first thing about baking headlights so I'm gonna just seal mine up with silicone to stop the fogging and hope for the best.
Old Oct 18, 2006 | 12:44 PM
Yanki01's Avatar
you should of just did a real retro with your stock housings instead of buying the ebay junk. Its not going to be cheap, and im not sure on how your going to fix the cutoff. Dont put HID's in those projectors, it will not look good at all!
Old Oct 18, 2006 | 01:47 PM
JfBriZ03's Avatar
My headlights also fogged up. So I spent many hours trygin to fix them without baking them. I used a hair dryer to attempt to dry them out and then applied silicone to basically everywhere I could where it was the cause of the possible leak. However, after 6 hours they still fog up. Not as bad as before but it is still there. I only think baking the headlights are going to fix this problem. And regarding the HIDs for these, I put them in my ebay projectors and they work good and look great. I have had nothing but compliments on they they look. So put them in!
Old Oct 18, 2006 | 11:22 PM
Hsua's Avatar
If you truely put silicone on your headlights already, good luck trying to bake them apart again. Silicone is made to resist very HIGH temperatures, so just to warn you before you melt something else... as for hid in those projectors, do you have a thread with pics?
Old Oct 19, 2006 | 12:00 AM
dannygenio's Avatar
these are the cheapest headlights in my life as soon as i bought it for 300 it dropped to 220 on ebay what kind of bull**** is that?
Old Oct 19, 2006 | 12:35 AM
Noodle's Avatar
You're right about silicone's heat resistance. So, you cannot break up silicone by baking, but it is very soft. You can just use a knife and run through it or just pull the headlights appart. Silicone can be a good sealant, but is is not strong. Well, depending on which type you use. After a retrofit, I use a clear silicon (weather and water resistance). When I need to open them again, I just run a knife through it and bake the head lamps, then open them w/o a problem.
Old Oct 19, 2006 | 07:49 AM
mFrosty's Avatar
ahhh do you guys know if they're going to make the ANZO Headlights with a black housing because if so I'm just going to get those...
Old Oct 19, 2006 | 06:19 PM
raWr215's Avatar
just spray it down with your desired color
Old Oct 19, 2006 | 09:52 PM
mFrosty's Avatar
Ya I know I'm just so tired of always having to mod stuff I just wanna buy it the way I want it lol
xBSciontist
Jun 18, 2019 03:06 PM
carid
Jan 8, 2015 11:33 AM
tc_Jake
Dec 31, 2014 01:45 AM
umnitza
Dec 1, 2014 06:26 PM
Scionic
39
Jul 20, 2004 02:46 AM
