Clear coat wrinkled paint, HELP!
Old Jun 13, 2008 | 03:58 AM
BZinn1's Avatar
Oh dear...........Corina it has been too damp and cold here the last two weeks to do any painting.............unless it is a heated shop with a dehumidifier going...........
You are gonna be in for some tired hands........if you have to use a paint remover tool like a sander pad.........that goes on a air drill or cordless drill and tear the paint off and then get to metal and prime it with black primer..........then after 48 hours of the rims beign in the warm temps inside hit it with the black paint.........let that sit for 48 hours after 4-6 coats.......light coats..........never paint thickly.......never.
after 48 more hours you can hit them with 4-6 light coats of clear..........
If needed I can come help get them right again..........I spend a lot of time painting stuff ..........this week is Cindy's cell phone case in the car color..........a girls gotta match.....
Old Jun 13, 2008 | 04:24 AM
iKONA's Avatar
Heres what you wanna do buddy, remove the paint with stripper or use like a 320 or 400 grit sand paper. Once its clean go ahead and apply the paint, do it in light coats but not too light. If its too light that = early paint failure by pealing. Your best bet is using medium coats on the light side. Then give it a 5 - 10 min flash time between each coat. Then clear the paint with 2 medium wet coats then a final wet coat, You dont want to let the paint sit for more then 8 hrs until you clear. there's a tack time with paint. So after the color you want to clear it after maybe 30 min. I give it about 20 min before I go over with a clear coat. If I'm shooting it form a gun I either use a medium coat and a thick final coat or 2 thick coats, if I'm rattle canning it I do 2 medium coats then a wet coat.
Old Jun 13, 2008 | 04:27 AM
iKONA's Avatar
ALSO! Keep in mind paint is chemistry. Only the right chemicals will work with each other and I learned this the hard way. I once used rattle can primer which was a lacquer primer on something for a friend of mine. THat worked well, then I used a urethane paint and clear and it started wrinkling like that. Usually if it wrinkles like that its either you had grease or oil on the wheel, or you had 2 chemicals that dont bond.
Old Jun 13, 2008 | 05:15 AM
ilovemytC's Avatar
^yeah, I used two different types of paint.
Weird, I just got home and almost all of the wrinkles have disappeared! I guess it was the temperature inside. I just finished sanding the lip and think I will leave it flat black instead of trying to clear them.
Old Jun 13, 2008 | 05:17 AM
ilovemytC's Avatar
Thanx Brian! I think all is well, the wrinkles have all but disappeared except on the wheel that was really bad. I wetsanded with 1000 and will wet sand some more with 2000 tomorrow. I kinda like the flat black look! But I'll see what it looks like in direct sunlight tomorrow...
Old Jun 13, 2008 | 05:26 AM
ilovemytC's Avatar
came home after 5 hours and they smoothed out by themselves. Sanded with 1000 and here they are now. I'm gonna sand the inside of the lip and leave them flat black:
Old Jun 14, 2008 | 12:00 AM
ilovemytC's Avatar
little more sanding and now they are on the ride! Whew! That took up almost my whole week of vacation!
2 days of driving and a bath:
Old Jun 17, 2008 | 04:47 AM
rocketpants's Avatar
What grit sandpaper did you use in the first place to sand off the chrome lip?
Also, what was the name of the black paint that u used? Duplicolor?
Old Jun 17, 2008 | 05:01 AM
ilovemytC's Avatar
^400 to sand off the chrome. 1000 to smooth the wrinkles/errors, 2000 to polish.
I used VHT caliper paint in gloss black and VHT caliper paint in Real Orange.
Old Jun 17, 2008 | 02:06 PM
a_german_named_hans's Avatar
interesting. Rims came out lookin good.
mc1114
Scion tC 1G Aero & Exterior
Aug 10, 2015 10:34 AM
Subaru86
Jul 31, 2015 04:00 AM
umnitza
Jul 25, 2015 07:54 PM
StxArOne
Jul 13, 2015 06:25 PM
