Complete Headlight Replacement?
Old Feb 16, 2018 | 08:05 PM
1lowufo's Avatar
Default Complete Headlight Replacement?
OK, Before I made a costly mistake, can I change both RH & LH complete Headlight Lenses on my 08 tC that HAVE the Projector Lenses, for 05-07 Headlight Lenses that are WITHOUT Projector Lenses, do they bolt right in?
I know I have to use different bulbs, I just don't want the Projector and I was told that the 05-07 models did not have Projector Headlights.
Moved to Correct Forum by Moderator
Last edited by MR_LUV; Mar 25, 2018 at 08:13 PM. Reason: Move to Correct Forum by Moderator
Old Feb 19, 2018 | 08:00 PM
Chaddup's Avatar
They should bolt right in. I went from the 05-07 without projectors to 08+ with projectors, and everything lined up perfectly.
Old Feb 22, 2018 | 12:11 AM
1lowufo's Avatar
I want to do the reverse....projectors to NON projectors! You still have your old lenses? Want to sell them? Hi beams are the same (9005) how did you change the low beam socket (9006) to a projector H11 ?
Old Dec 2, 2018 | 12:01 AM
Darkwolfca's Avatar
sure you figured it out but for others you can get Adaptor harness's to change from one bulb to the other on amazon, ebay, make yourself.
1lowufo
Scion tC 1G Aero & Exterior
Jan 26, 2018 08:08 PM
topher86
Scion tC 2G Aero & Exterior
11
Dec 15, 2011 07:05 PM
notoriouseyk
Regional - Pacific Mid
Mar 30, 2010 03:52 AM
AndyInOC
Jan 29, 2009 02:03 AM
enufced904
May 21, 2007 05:46 PM
