Front hood not closing tightly? ( pic inside )
Old Mar 16, 2010 | 02:49 AM
kayi078's Avatar
Default Front hood not closing tightly? ( pic inside )
I got this car couple weeks ago from local dealership. I just noticed the driver side of the hood not closing tightly. When I push the bumper up the gap is smaller. It looks ugly in person. I have my mechanic inspect it after I bought the car and he said the car should had no any accident before.
what makes it like that?? Any solution?? Please help!
Old Mar 16, 2010 | 03:01 AM
05_2tone's Avatar
check the bolts around the hood hinges to see if hood has been off of car b4
Old Mar 16, 2010 | 03:09 AM
kayi078's Avatar
its the problem from the hood or the bumper???
Old Mar 16, 2010 | 03:15 AM
05_2tone's Avatar
if the bolts have been moved on the hinge then its ur hood , also check to make sure all the clips are in the bumper
Old Mar 16, 2010 | 03:56 AM
The01Cav's Avatar
From the pic, it looks like the hood allignment is actually off, the gap on the passenger side between the hood and fender looks more open than the drivers side is.
Old Mar 16, 2010 | 04:23 AM
aryan13's Avatar
See if adjusting the rubber bump stops located on the radiator support do anything.
Old Mar 16, 2010 | 05:24 AM
burstaneurysm's Avatar
^ Yup, check those rubber bumpers first... they twist, I think clockwise is lower, counter clockwise is higher.
Old Mar 16, 2010 | 06:07 AM
SquallLHeart's Avatar
^^ x3
rubber stops was my guess too.
Old Mar 16, 2010 | 07:37 AM
FlintMica2005's Avatar
x4 rubber stops
Old Mar 16, 2010 | 08:04 AM
DeathStalker's Avatar
check the screws that hold up the bumper cover, once you lift up the hood they should be right in front of you. the rubber stoppers might be it also.
measure the gaps left and right between hood and fenders, rad support color, overspray, this will help to figure out if its been crashed at any part. you can crash a car and fix it without a paper trail.
Old Mar 16, 2010 | 10:52 AM
kayi078's Avatar
any pic..no idea where is it...
Old Mar 16, 2010 | 11:06 AM
Big_Bird's Avatar
It's just the black rubber bump stops. You'll know them when you see them. They're right in front of you when you look down at the engine bay.
Old Jun 17, 2010 | 06:27 AM
kayi078's Avatar
Check the rubber stops and it is not the problem...its more likely a dent from the front bumper, how to fix?
Old Jun 17, 2010 | 02:48 PM
Young-Gun's Avatar
Pictures of the dent? I don't see how a dent can cause that...
Old Jun 17, 2010 | 04:26 PM
tin's Avatar
tin
Thats how my hood looks like. Just like that. It got like that after my accident. I went under a ford explorer and it wrecked my driver side fender and dented my hood. I thought they replaced the hood but no they just ''fixed it''/ Check the history on your car. How does your head light sit?
Old Jun 17, 2010 | 05:29 PM
ScikoTRDtC's Avatar
maybe a fat girl sat on it :0
fur_pig
Mar 20, 2020 04:28 PM
mischman
Jan 14, 2015 06:07 PM
umnitza
Dec 1, 2014 06:26 PM
Joeynenj
Nov 25, 2014 05:29 AM
