headlight swap question
Old Nov 19, 2011 | 12:07 AM
testa422's Avatar
Default headlight swap question
so i have an 08 with projectors now and im thinking of buying some 05-07 heads...any wiring issues i will run into when trying to get em to work with my 08? thanks
Old Nov 19, 2011 | 12:27 AM
TimmyWanaBreak's Avatar
Just for the low beams, if you have hid's...you can connect the 9006 bulb directly into the stock H11 harness. Its really simple and no pig tails were needed. The male connectors on the bulb just needs to be removed from the black plastic thats around it, which doesnt fit into the harness. You remove it by cutting it open and removing the connectors out of that black plastic. Then you can easily just directly plug it into the harness. Make sure to electrical tape it horizontally together and veritcally so it wouldnt get disconnected/water.
Old Nov 19, 2011 | 12:31 AM
Jon's Avatar
Jon
Moderator
Moderator
It's the same as if someone was swapping from 05-07 to 08. Low beams won't match, so either use HIDs or get conversion harnesses.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
S7ephavs
Mar 22, 2015 12:09 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
