HID Relay problem need help!
Old May 9, 2008 | 09:20 PM
FREEradical's Avatar
Default HID Relay problem need help!
Hey I'm trying to install my relay harness for my HID's but the part of the relay which plugs into my stock harness seems to not fit. The two metal prongs are too big to fit into the stock plug, can I just grind them down to size until they fit? I'm trying to figure out why only that part wouldn't work, the HID kit I bought has H11 bulbs (for the anzo headlights I have) , but I don't really see why that should change the size of the connector for the stock harness that just has to do with bulbs right? Would just trimming the prongs to fit into the stock harness be a bad idea or does it not matter as long as the metal contacts complete the circuit??
Old May 10, 2008 | 05:28 PM
Not one person can say one thing to help? Does no one on here have hids or a relay? where are the engineers and electricians and dudes who know stuff? Come on someone help me out.
Old May 11, 2008 | 07:08 PM
heybog's Avatar
For the relay, you should be fine as long as you make the connections for 12V and ground.
Old May 11, 2008 | 07:12 PM
bB384's Avatar
IV ACE
Where are you located? If you're So. Cal. maybe we could meet up and I could help you out.
Old May 12, 2008 | 07:04 AM
Nah I'm across the country in PA, I mean the question isn't that hard though. You know the part of the relay that plugs into the stock harness? Well there are two prongs on that, like any electrical plug that goes into a wall. The problem is the prongs are too large to fit into the stock harnesses holes, so can I just trim the prongs with my dremel until they fit into the holes, or is that gonna cause some kind of electrical fire or something?
Old May 15, 2008 | 01:06 PM
chaseonbass's Avatar
does anyone know if you connect the positive and negative of the relay straight to the battery? or does the black get connected to ground?
S7ephavs
Mar 22, 2015 12:09 PM
GetSlideways
Scion xD Drivetrain & Power
Mar 16, 2015 11:30 PM
GoodVibes
Mar 10, 2015 04:29 AM
idriveanxa
Mar 8, 2015 12:03 PM
tc_Jake
Dec 31, 2014 01:45 AM
