HOW TO: Tint TYC taillights
Old Apr 12, 2009 | 03:27 AM
  #81
FLEA's Avatar
Originally Posted by jsingh
hey kennon i got a question...i don't have dual action buffer would a 20$ buffer from walmart work for this or should i buy mother's polishing ball? OR just do it by hand?
thanks
$20 buffer won't be the best, but it'll be a whole lot easier than doing all of it by hand.
Old Apr 12, 2009 | 03:32 AM
  #82
FLEA's Avatar
Originally Posted by luuserface
why'd you move the DIY kennon?
I was approached by that site and they asked if they could post it up on theirs instead. Figured it'd get more daily hits there...rather than here.
Old Apr 13, 2009 | 10:03 PM
  #83
jsingh's Avatar
OhioScions
hey kennon i painted my tc's tails they turned out great, then i started doing my bro's caddy and when i painted them, now they have cracks...do u know what would have caused this?
thanks!
Old Apr 13, 2009 | 11:17 PM
  #84
FLEA's Avatar
Number of things. Bad prep work, no adhesion promoter, coats too wet.
Old Apr 14, 2009 | 05:51 PM
  #85
jsingh's Avatar
OhioScions
they were well sanded, and i tried it 2 times and still crack looking..i don't know why? and i did'nt used a adhesion promoter...should i redo them?
Old Apr 15, 2009 | 07:50 AM
  #86
FLEA's Avatar
^ Absolutely! Why wouldn't you? Do they want the cracked effect?
Old Apr 15, 2009 | 08:12 AM
  #87
luuserface's Avatar
What's an adhesion promoter? (Noob question possibly)
Old Apr 15, 2009 | 08:52 AM
  #88
FLEA's Avatar
Basically a clear transparent primer.
Old Apr 15, 2009 | 03:07 PM
  #89
luuserface's Avatar
how come I didnt use it when I used vht?
Old Apr 25, 2009 | 03:23 AM
  #90
layedoutxa's Avatar
I have a question... I cleaned my tail lights, and then I sprayed them with VHT nightshades... there was a small place that looks like dirt got on. I wet sanded them, and now the spot is gone. Instead of it being shiny looking, it's dull and sanded looking, yet smooth. Do I just wipe it clean and then spray clear on it? or...
Old Apr 25, 2009 | 03:50 AM
  #91
FLEA's Avatar
^Yes. Wipe it clean with a tack cloth.
Old Apr 25, 2009 | 08:21 AM
  #92
layedoutxa's Avatar
Even if some areas on the tail lights look chalky and not completely black in areas? Just wanna be sure :D
Old Apr 25, 2009 | 08:36 AM
  #93
FLEA's Avatar
Why do they look chalky, you not spray the coats on evenly?
Old Apr 25, 2009 | 11:21 AM
  #94
layedoutxa's Avatar
Because I wet sanded them.
Old Apr 25, 2009 | 04:01 PM
  #95
FLEA's Avatar
If you wet sanded them they shouldn't look chalky. Post a picture of what they look like.
Old Apr 28, 2009 | 02:03 AM
  #96
layedoutxa's Avatar
Here are some pics:
Old Apr 28, 2009 | 02:49 AM
  #97
FLEA's Avatar
You need to wet sand more. Looks like you wet sanded just parts of it. Go in a back and forth motion...not circular.
Old Apr 28, 2009 | 03:03 AM
  #98
layedoutxa's Avatar
But they should look like this right? The dull areas are okay before clearing them yes?
_ I didn't do circular, I did back and forth, just moved as the angle of the lights changed.
Old Apr 28, 2009 | 03:31 AM
  #99
FLEA's Avatar
^Yes. you want it to look like a dull/flat finish, then clear coat it.
Old Apr 28, 2009 | 03:40 AM
  #100
layedoutxa's Avatar
Okay, Thanks for your help, I'll finish wet sanding it
