Just did 9006 to 9005 headlight retrofit mod (pix)
Old May 26, 2006 | 05:28 AM
skiboarder72's Avatar
Default Just did 9006 to 9005 headlight retrofit mod (pix)
As many of you know you can do a simple mod to fit a 9005 high beam bulb (1700 lumens) to fit in our regular 9006 (1000 lumens) sockets (HID's are 3200 lumens). The mod was very easy to do and only cost around 20$ (I used 2 9005 slyavania cool blues). The beam pattern is the same hieght just 70% more powerful now. Here are some pix.
9005 cool blue on the left, stock 9006 blub on right
Stock 9006
9005 slyavnia cool blue
Beam shot, not the best i know but you can see the 9005 bulb on the right does go farther and is slightly brighter, looks better in person
Here is a good writeup... works the same for our cars
http://www.bmwe34.net/E34main/Upgrade/More_light.htm
Old May 26, 2006 | 07:59 AM
titolito's Avatar
I know nothing about lighting, so bear with me....
So basically your "low beams" will be just as bright as your high beams, right? So isn't that like driving around with your high beams all the time? Isn't that inconsiderate to other drivers? And what about your "high beams?" Their not high anymore! Their just like your "low beams." Is that right?
Old May 26, 2006 | 08:15 AM
Hyghgynx's Avatar
^^There is a link provided within the link for adjusting the modified 9K5 bulbs after install. I hope he did that because I wouldn't want to see him coming my way and being blinded!
reagulator's Avatar
in the tC the high and low uses different reflectors. so the highs have a focal point so it aims more straight and the lows are aimed lower. so using a "high" bulb in a "lowbeam" housing will yeild a brighter low beam
Old May 26, 2006 | 08:16 AM
bubblemyster's Avatar
can anyone say glare.
Old May 26, 2006 | 02:43 PM
yea no problem using the high beam bulb, all you are going to do is get a high beam brightness low beam, NOT the high beam blinding effect
you can see the light beam in the picture does not go any higher (up the trees) than the stock bulb also
Old May 27, 2006 | 12:19 AM
06SuperWhite_SoCal_tC's Avatar
Putting in the Cool Blue bulb you kinda defeated the purpose of trying to make your lighting brighter. The blue tint on the bulb filters out some light, making it dimmer. You would have been better off just switching to a Toyota OEM 9005 Bulb.
Old May 27, 2006 | 12:22 AM
The_Instigator's Avatar
Ive been running 9005s in my lows and fogs for about 10 months now and its great. I dont get flashed by other drivers and visibiltiy is amazing. Im pretty sure the eyelids are keeping the glare in control because I have done zero in the way of adjusting the beams..I was ready to but based on my results I saw no need.
Old May 27, 2006 | 08:10 PM
JOEinSD's Avatar
Aren't 9005s a higher wattage?
Old May 27, 2006 | 08:56 PM
Tecrun19's Avatar
Well i know the stock Highs are 60watts so yeah they are higher
Old May 27, 2006 | 09:19 PM
JOEinSD's Avatar
soo wouldn't you running the risk of burning your harness? just curious because im running 55w bulbs and afraid to burn the harness already.
Old May 27, 2006 | 10:17 PM
nytlemgr's Avatar
thanks foe the info. and link
Old May 28, 2006 | 12:45 AM
actually the 9005 high beams are 65 watts, theres no problems as the jump isnt big enough to harm the harnesses
Old May 28, 2006 | 04:38 AM
heres a pick of them from tonight
Old May 28, 2006 | 05:02 PM
Tecrun19's Avatar
Hmm so no one has had a problem with this yet ? Reason I ask is becuase i just read all those Luminecs stories of peoples harnesses being fried by only a 5watt jump from the bulbs, this is like a 14watt jump with the high beam bulbs
Old May 28, 2006 | 06:44 PM
JOEinSD's Avatar
That's what I was tryinig to refer to but without naming names. Lol.
well i havent had any problems and i've had them on for 30 minutes at a time before... and the guy above has been running them for 10 months no issues...
Old May 29, 2006 | 05:08 AM
Tecrun19's Avatar
Well just did these today and yeah they are brighter and the light pattern is the same as the stock 9006's. Just hope it doesnt burn the harness now
Old May 29, 2006 | 07:20 AM
JOEinSD's Avatar
30 minutes at a time? you only drive in incriments of 30 mins at night?
Old May 29, 2006 | 07:48 AM
Garage1217's Avatar
Keep this post updated if any of you have harness issues!
