oem lip question
Does anyone know what the tabs on top of the lip are for? The lip won't fit without removing them. I can send a pic to anyones cell phone if you don't know what I'm talking about. Its kinda hard to describe it
you need to cut tabs into your oem bumper and they are clipped from the other side
here V
http://trdsparks.com/install/PT47A-21053inst.pdf
here V
get your dremel and they have marks on the inside of your bumper to guide you exactly how wide and how long you need to drill the slits.
good luck just take your time and like you said it will be more secure with the clips.
its not necessary to cut your oem bumper, just cut the tabs off and use double sided tape, the tabs is just the way its suppose to be installed, but its like any other lip, double sided tape, screws on the ends, and voila!
^you dont see any other lips flying off, look at the five axis, its installed the way i described, double sided tape all around and screws on the ends, and its not going anywhere
Beesh
Jan 9, 2015 06:30 PM
TheTripleC
Jan 4, 2015 06:46 PM
