Painting the VVTi engine cover
Old Oct 27, 2006 | 12:48 AM
Crayola_G's Avatar
Default Painting the VVTi engine cover
So my cars in the shop, and i wana kill some time, and i have the vvti engine cover siting in my garage, so i wanted to do somthing to it, i was thinking ... painting it. How do you guys gonig about doing that?....Does reg. paint melt?....How did you paint it?
Old Oct 27, 2006 | 02:06 AM
tcsport's Avatar
Sand, primer, paint.
Use high temp engine paint. Most auto stores carry it. But why paint? Go powdercoat it!! Or is the cover plastic?(dont own a tC yet, so I dont know, )
Old Oct 27, 2006 | 02:14 AM
Crayola_G's Avatar
yea its plastic
Old Oct 27, 2006 | 03:52 AM
Hyghgynx's Avatar
Just clean it really good with mineral solution or rubbing alcohol. No need to sand and primer. Use a High-Temp paint (Dupli-Color for instance) and a clear coat. 3-4 coats of each and rock on...
You could do this project in less than 30mins.
Old Oct 27, 2006 | 04:06 AM
Somnambulated's Avatar
That looks so clean it could be factory. At some point I might even sell my CF engine cover, and go for the painted look.
Old Oct 27, 2006 | 06:26 AM
Crayola_G's Avatar
sweet. im gona do it thx
Old Oct 27, 2006 | 02:29 PM
Borisimo's Avatar
Will the clear coat take the high temps?
Old Oct 27, 2006 | 02:32 PM
krdshrk's Avatar
I might have to redo mine. Clearcoat would look great on it. I actually just cleaned it off and sprayed it with Krylon. It's not high-heat but it's lasted a long time, with no chipping, peeling, or cracking. I've taken some long distance trips too.
Old Oct 28, 2006 | 01:36 AM
Andrew1782's Avatar
How did you do your lettering?
Old Oct 28, 2006 | 01:43 AM
CatalepsicFox's Avatar
Actually instead of using Primer on the plastic... I recommend using Adhesion Promoter.
Old Oct 28, 2006 | 05:50 AM
Hyghgynx's Avatar
I cheated! It's a vinyl sticker. A guy named Randode who frequents this site can hook you up with the sticker for like $6.
As for the clear coat taking high temps; I haven't had a single issue and my Engine Cover has been painted/cleared for over 4 months now. It looks the same now as it did on day 1 of this mod.
Old Jan 16, 2007 | 04:49 PM
tjbartjr's Avatar
Would regular automotive paint (stuff you'd use to repaint your car) stick to the p[lastic, or would you have to use any special primers or anything?
Old Jan 16, 2007 | 07:14 PM
Neothin's Avatar
auto paint works just fine. That's how i got mine painted to match my nautical blue exterior color.
Old Jan 16, 2007 | 07:19 PM
bay-area-cracker's Avatar
I like it, I was thinking about doing mine in red.....
Old Jan 16, 2007 | 07:26 PM
jjos1's Avatar
Powder coating is the way to go
Old Jan 16, 2007 | 07:30 PM
That looks sweet... where did you get the VVT-I plug cover?
Frosty355's Avatar
I painted mine a year ago. 2 steps
1.Clean really well
2.Paint with Krylon fusion for plastics.
Looks as good as the day I did it. I often clean it when I go to the car wash with a little blast of water.
Old Jan 16, 2007 | 07:34 PM
jjos1's Avatar
I make them, and powder coat them
Old Jan 16, 2007 | 09:40 PM
fox's Avatar
fox
Yeah, i did the cover, fuse box cover and the TRD swaybar all at the same time. The K&N intake came like that
Old Jan 16, 2007 | 09:42 PM
Neothin's Avatar
^ you should paint the letters + emblem to make them stand out
