Rear hatch rattle
Old Jan 14, 2019 | 02:18 AM
backroad101's Avatar
Default Rear hatch rattle
So my rear hatch is rattling and I wanted to replace what seem to be worn out bump stops.
Does anyone know the official name for these of have a part number?
I have been searching Google and have not found anything.
__________________
Old Jan 14, 2019 | 02:38 PM
J_Leon's Avatar
If Iam not mistaking according to what you described this what you are referring to.....
https://www.sparksparts.com/oem-part...w0LWdhcw%3D%3D
Old Jan 14, 2019 | 10:33 PM
Actually I was looking for the lower ones but this definitely gets me going in the right direction.
Thanks
Old Jan 15, 2019 | 01:56 AM
MR_LUV's Avatar
Administrator
Administrator
I THINK you need Item #6, Door Shell Bumper, Part No. 90084-54012
Hope this Helps,
MR_LUV
Old Jan 16, 2019 | 04:52 AM
62Fender's Avatar
Originally Posted by backroad101
... wanted to replace what seem to be worn out bump stops.
If your bump stops aren't melted or bent, self stick furniture pads will stop the clunk.
Old Jan 21, 2019 | 01:55 AM
xdejablu3x's Avatar
Please do explain where would one install that on the hatch because I've been battling this for years with to no avail. All the DIYs I found were utterly useless and didn't solve my issues because there some slight design differences over the years during the first gen Scion tC.
Old Jan 21, 2019 | 12:48 PM
62Fender's Avatar
I installed the furniture pads on the rear bumper cover. Look for the circular or semi circular divets (where the lower hatch bumpers rest against the bumper cover.) The furniture pads should help keep the upper, hard-rubber hatch bumpers from clunking together.
Old Jan 22, 2019 | 10:58 PM
I did the same but screwed them on which worked well for a while but ended up ruining the part.
Old Jan 22, 2019 | 11:18 PM
62Fender's Avatar
Ruined your bumper cover or the hatch bumpers? I've had the self-stick type since 2012 and they're still stuck tight.
Old Jan 26, 2019 | 06:40 PM
Ah, just realized you said bumper cover. No I did not do that. I put them on the hatch bumpers
So my question is do these hatch /cushions/isolators wear out? Wondering if I need to buy new ones or save money and get some at the salvage yard and put better stick on pads on those.
For anyone questioning the parts I am looking at, referencing the pic above
#2 67281-21020 Lift Gate Stopper
#4 67893-21020 Lift Gate Upper Insulator
__________________
Last edited by MR_LUV; Jan 26, 2019 at 10:43 PM. Reason: Insert Diagram for #2, #4
Old Jan 26, 2019 | 10:02 PM
62Fender's Avatar
According to MR_LUV, you need item number 6.
Old Jan 30, 2019 | 03:10 AM
dogg's Avatar
OMG...i have an 08, why would you even need to replace these "bumpers"??? whichever ones you are talking about...just curious (i dont understand)...what the heck are you doing to them that requires them to be replaced???
edit: i gotta know...
Old Jan 30, 2019 | 03:29 AM
62Fender's Avatar
He screwed furniture pads to them.
Old Jan 30, 2019 | 03:31 AM
dogg's Avatar
But...WHY???
Old Jan 30, 2019 | 12:24 PM
62Fender's Avatar
The lower hatch bumpers are too short to prevent the upper rubber bumpers from clunking together.
Old Jan 31, 2019 | 06:57 PM
Anyway, thankfully it will be 40 degrees tomorrow (50-60 this weekend) and will stop at the junkyard tomorrow and get this rattle taken care of . It is a lot worse with this polar vortex :-)
Old Feb 4, 2019 | 11:26 PM
Got the parts at the salvage yard. Put them on, added some furniture pads and ahhhhhhhhhhh hatch rattle gone on drive to work today.
Old Feb 5, 2019 | 04:04 AM
62Fender's Avatar
Good to hear. If it's like mine, now you'll be able to hear he other rattles.
Old Feb 6, 2019 | 03:23 AM
Hahhaha. It's funny because it is true :-) In my case it is the strut mounts at low speeds. One thing at a time (and warm weather)
* Note: Thread Locked by Administrator
myselfdotcom
31
Oct 6, 2019 08:21 AM
Skeeterflea
Nov 3, 2014 09:40 PM
HR_Guy
Mar 12, 2008 03:28 AM
bikemike
Dec 5, 2007 10:29 PM
Rivulent
Jan 3, 2006 04:06 PM
