removing eyelids...
use the same method you possibly used putting them on...start to peel from one side and use soapy water and should come off easily. thats what i did on my first pair when i put new ones on afterwards. but i guess the goo gone should work as well. either way will work.
But be careful... some adhesive removers can be abrasive to plastics. I worked for a vinyl company for a while... You don't ever want to use an adhesive remover on headlights/taillights to be safe. Heat and Peel is the ultimate best bet!!! If you heat too much you can warp the taillights too! Prob not the headlights though as they are designed for more heat.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
steeze69
May 24, 2021 02:57 AM
