TYC Lights..Bulb Replacement?
Hello everyone!
I have a 2007 Scion tC. The driver's side tail light has gone out. Is there any way of replacing the bulbs?
Or must I replace the entire assembly to get it working again?
I'd like to do the maintenance myself if I can.
_______
_______
If the lights are stock 2007, the bulb sizes are as follows - Car Replacement Light Bulb Size Guide - 2007 Scion tC - ModifiedLife
There should be an access panel in the hatch that you can pop off to view the back of the light, then usually you just twist and pull a socket to replace the failed bulb.
If your lights are aftermarket LED though, then you might need to replace the assembly depending on which bulb is out.
rockthebeef
283
Oct 30, 2025 01:52 PM
randomsuper
Jan 25, 2015 01:09 AM
Dark_Blue_XB
Nov 15, 2012 08:10 AM
Womenlover
Nov 2, 2005 12:01 PM
