VRD HID problem help :(
Hi guys,
I have a bit of a problem, i have hid's on my vrd fogs and today suddenly both of my hid will not go on.
I understand that they can mess up ballast etc, but is it not weird for both of them to suddenly go bad at the same time?
Is there a fuse i should check out if so which. I have my fogs wired so they are n with parking lights and parking lights still work.
Any help would be appreciated
which would you say because i look at the back panel of the fuses and i dont rly see one related to the fogs
which fuse should i be looking for
Ill do my best, i didnt get the car with onwers manual. Ive searched but couldnt find something solid to check fuses.
If anyone knows something that could cause this lemme know, again its very weird for both to zonk out.
p.s. sorry if im asking allot but i searched allot before asking. Could find a solution, except for checking with istruments like the other tc member said( which i dont know how to do)
theres must be a explanantion
hmmm checked ground they sem to be fine
going to a shop to see what it could be...thought maybe fried cables or something but they look fine.
the vrd wiring did come with a relay maybe its busted.
how do you tell a relay has died?
bah....i dunno anymore. I had a guy come over and tested the hids, they where fine.
I hear the switch clicking but when they tested the wire going to the ballast it wasnt getting any juice....any ideas? and can a rekay be busted and still switch?
OMG please say your joking, please excuse me but is it the fuse in the interior of the car where the switch is???.....because for the life of me i cant find the one labeled fog. Explain to me where it is exactly please, sry to be a bother. Im not trying to come of lazy but i dam near dissasembled everything im still messing around with it as we speak
if its just a fuse ill stab myself with a spork........ i honestly see non labeled fuse
it's labeled "FR FOG"
here's a 2005 owner's manual... location should be the same if not close by depending on what year your car is
http://scionlife.org/Scion_Docs/2005...IFICATIONS.pdf
......well its time to head to kfc to buy some mash...gonna need that spork.
omg tnx heart....i neverrr knew there where those fuses under the dash...i was like no way. the car is second hand and i never had the manual. you were a great help....time to assemble again
. something sooooo small omg.
i would advise you to use a relay harness for that HID setup, otherwise there is a possibility that fuse may blow again.
also note: never install a fuse that is rated higher than the one that is supposed to go there.
S7ephavs
Mar 22, 2015 12:09 PM
minter66
Dec 15, 2014 01:45 PM
