Wind Deflector Rattle fix TSB
I got access to a school computer in autoshop and looked up info for the annoying rattle in my sunroof that everyone is having. This is what i could copy and paste, sorry that i couldnt provide the pix that came with the service bulliten, but at least you know scion has a solution for the problem.
January 30, 2006
Title:
WIND DEFLECTOR RATTLE
Models:
'05 Scion tC
Introduction
Some customers may experience a rattle noise from the moon roof wind deflector pivot points. A new spacer has been designed to help reduce this condition in that area.
Applicable Vehicles ^ 2005 model year Scion tC vehicles produced BEFORE the Production Change Effective VIN shown below.
JTKDE177159936999
I cant post the images to the installation and the charts but i will provide u with the part number.
67546-21010 for the E-ring qty 2
63239-21030 for the spacer qty 2
Warranty Information
Applicable Warranty:
This repair is covered under the Toyota Comprehensive Warranty. This warranty is in effect for 36 months or 36,000 miles, whichever occurs first, from the vehicle's in-service date.
* Warranty application is limited to correction of a problem based upon a customer's specific complaint.
Repair Procedure
NOTE: Perform the Repair Procedure on both the LH and RH side.
1. Fully open the moon roof to access the wind deflector lift arm pivot points.
2. Using a small flat head screwdriver or pick, remove the E-ring from the pivot pin.
3. Slide the pivot pin out.
4. Install the spacer between the lift arm and the wind deflector bracket.
5. Apply body grease to the pivot pin and reinstall using the NEW E-ring.
© 2007 ALLDATA LLC. All rights reserved.
January 30, 2006
Title:
Models:
'05 Scion tC
Introduction
JTKDE177159936999
Repair Procedure
Any word on the 07's? Mine has the most annoying noise coming from it, it almost sounds like the glass is cracking when it is in the barely open position, where no light is coming in from up above. Like nodsetse said, it is the only thing "wrong" with my car, albeit only 3 months old.
i read about the 07 cracking noise in the sunroof when driving on rough roads. It was sontin about the over torqued bolts when the body is flexing. Um I'll get the TSB on thursday and post it about that cracking noise issue.
Ok this is the deal. I got access to the TIS but all the info and fixes are in secure login PDF format. If you want the TSB to anyproblem you have email me @ kamileon88@optonline.net please put in your scion problem and i'll send you the PDF file as soon as i can. PLEASE DO NOT POST YOUR EMAIL HERE, I WILL NOT REPLY TO YOU CAUSE IM LAZY hahahaha
Email it to vitviper@hotmail.com
I've got some stupid issue with my sunroof rattling and squeaking now :/
thank you so much~
mc1114
Scion tC 1G Aero & Exterior
Apr 23, 2020 10:34 PM
scioninla
31
Jan 10, 2004 12:56 AM
