09 tC Cooling Fan issues HELP!!!
Old Aug 6, 2021 | 09:11 AM
eskimo_brr's Avatar
Default 09 tC Cooling Fan issues HELP!!!
Please help!!!!!
so my 09 tC cooling fans doesn’t turn on when engine temp is high and the only way I been dealing with it is by driving with the A/C on because
the fans work. It just doesn’t turn on when need be. I replaced the whole fan assembly, coolant temp sensor, coolant flush and thermostat all OEM.
PLEASE HELP ME!!!!!
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; Aug 6, 2021 at 11:52 AM. Reason: Moved to Correct Forum by Administrator
Old Aug 6, 2021 | 03:40 PM
DannoXYZ's Avatar
Moderator
Moderator
do you have multimeter and know how to use it to measure voltage and resistance? This is literally 5-minute repair with voltmeter.
Old Aug 7, 2021 | 01:59 AM
eskimo_brr's Avatar
Default Response
No I don’t and I don’t know how to use one but I changed the relay fuses things and that didn’t help
Old Aug 7, 2021 | 02:21 PM
62Fender's Avatar
Here's a few more things you can check.
Cabin Fuse Box:
AM1 Fuse
ECU-IG Fuse
Engine Bay Relay/ Fuse Block
FL MAIN H-Fuse
ALT H-Fuse
CDS H-Fuse
RDI H-Fuse
IG1 Relay
Cooling Fan Relay 1, 2 and 3
Old Aug 9, 2021 | 03:52 AM
eskimo_brr's Avatar
Cabin Fuse Box:
AM1 Fuse
ECU-IG Fuse
FL MAIN H-Fuse
ALT H-Fuse
CDS H-Fuse
RDI H-Fuse
IG1 Relay
thanks for responding I will check Tommorow morning and I’ll post a update !!!!
NOWY579VWT
Apr 26, 2022 08:26 PM
BraddaEdz
Dec 9, 2020 06:17 AM
DeadChickenUpMyAss
Jul 22, 2017 06:24 PM
Forced4
Aug 25, 2015 08:18 PM
hardlucktattoo
71
Oct 19, 2011 05:31 PM
