2 fans, One only working..Help!!
Hey, so I was changing my oil and I noticed one of my fans wasn't spinning. (The one on the driver's side) the A/C was on. I don't seem to have any problems, A/C blows cold and good.
Engine hasn't overheated. I did notice a slight drop in coolant tank but very small. I filled it higher than full mark and now its at the full mark. Its a 2007 with 160,427 miles.
Can anyone help? Before I take it to a mechanic.
Sticky How To Advanced Search SL (Scion Life)
______________________________
Last edited by MR_LUV; May 23, 2020 at 09:52 AM. Reason: Moved to Correct Forum by Administrator
You should check the fuse for the fans first to see if it is blown first. Then check to see if the fan wiring harness is damaged and see if it voltage reads 12 volts. If both the fuse and wiring harness are fine it is most likely the fan itself.
https://www.700r4transmissionhq.com/...n-not-working/
Thank you, i will check it out.
Ch1018
Feb 18, 2020 10:32 AM
TaxiXB
Jan 18, 2019 03:00 PM
