Cams for the TC?
Originally Posted by BeaumontTC
WOW! Thats some good help. I'm probably going to do a S/C build up. So with a S/C, full exhaust, 3" piping w/HKS high flow muffler, DC race header, s/c air intake, light weight flywheel, bigger injectors, bosch 110 spark plugs, light weight crank pulley, underdrive pullies, & 11psi S/C pullies I should be putting out good power for a daily driver.
Might want to add in a clutch and LSD to that list. Gotta put the power to the ground. Just incase there is confusion, Maximum Boost is a book about designing, testing and installing turbocharger systems, not the comic strip from ImportTuner. I figure I'll just quote the other so you can yell at him not me if you need to.
"Make no mistake in the fact that turbo performance cams are very different from atmospheric performance cams. The characteristics of long-duration and high overlap for atmo cams are unwelcome in a turbo system. The street turbo, which is generally small, operates with exhaust manifold pressure somewhat higher than intake boost pressure. This situation, when presented with long-duration, high-overlap cams, creates a huge amount of reversion. Thus the "turbo cam" tends to become a low-duration, very limited overlap cam" (Corky Bell). He continues with a little hand pointing at the word: RULE, in bold and after it there is "It is hard to find a turbo cam that works better than the stock item." Now I know this is 2006 and the book is copyrighted 1997 so the information may have changed. But for some of us I guess money isn't an issue.
I think for now, you may be able to get good results with FI by reducing vvti overlap with a camcon. Of course, you would have to pay for the part and the tuning session. Anyone know if the unichip/emanage can control variable valve timing systems?
i don't know alot about the scion engine but i do know that the piggy back system do sometimes conflict with the ecu. mostly with the the cam angle sensor. i don't know what the end result would be but i would think it can't be to good
2 drive GST Eclipses
Geez I want cams already haha soon perhaps I could have sworn I saw a post somewhere around here where a company was talking about they were in the process of making some turbo cams....I think it was dezod but dont quote me on that. All I wanna say is SOMEBODY ANYBODY HELP!!! peace.....
steeze69
May 24, 2021 02:57 AM
gedster314
14
Nov 17, 2018 02:56 PM
