camshafts
Old Mar 1, 2006 | 01:31 AM
wc01's Avatar
Default camshafts
does anyone make cams for the tc can you even put aftermarket cams on?
Old Mar 1, 2006 | 05:43 AM
hahaitzskippy's Avatar
we are all still waiting
Old Mar 1, 2006 | 01:53 PM
tuningvelocity's Avatar
Default re
im waiting to....
Old Mar 1, 2006 | 02:13 PM
jons_tc's Avatar
Is there word of what company is going to fabricate them?
Old Mar 1, 2006 | 04:26 PM
PghtC's Avatar
hopefully Colt cams or someone will make something...
golden eagle and crower,
Old Mar 2, 2006 | 11:58 AM
PghtC's Avatar
well someone, don't care who. would be nice if there would be the option.
Old Mar 2, 2006 | 12:21 PM
tcengel's Avatar
I would say that cams would be worthless in this engine. With such a low rev limit you are going to end up with a very small powerband that will only make your car slower.
If you changed the cams, heads, springs, retainers and pistons then maybe it would be worth it. I'd say just work on the heads for the most power.
Old Mar 2, 2006 | 07:10 PM
wc01's Avatar
elaberate plz
Old Mar 2, 2006 | 07:16 PM
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
you would most likely benefit more with cams in a F/I engine rather than all motor
Old Mar 2, 2006 | 08:09 PM
tcengel's Avatar
Originally Posted by wc01
elaberate plz
Performance cams will shift the powerband to the right, and trade low end torque for torque at higher RPMS. If the head can't flow or handle higher revs, what's the point?
Old Aug 31, 2006 | 12:32 PM
Gmoney's Avatar
Seven City Scions
Camshafts can and will up the power in these vehicles. With a 96mm bore this vehicle would benefit greatly from more duration and more lift. Camshafts won't neccessarily shift the RPM band. If you design a camshaft to work in a given RPM band then it will do its work. Camshafts in this vehicle are restrictive to meet MPG ratings just like honda, nissan, GM, etc. No manufacturer is gonna max out these parameters in a passenger vehicle. I do agree with TCengel about the head, if it doesnt flow than nothing will up the power. The best bet for N/A would be to get some 2AZ-FXE pistons (if its possible giving engine variants), larger bumpsticks, Port & polish the head, and i/h/e.
FYI-This isnt Gmoney, this a fellow employee (Honda owner).
Old Aug 31, 2006 | 04:37 PM
Keeshwah's Avatar
Could the FE engine handle that much compression? The FXE is Atkinson cycle. Please enlighten me.
Old Aug 31, 2006 | 04:43 PM
marinoTC's Avatar
zpi has the stage 2 head. they say with the greddy e-manage system you can bump up the rpm's to around 7500
Old Aug 31, 2006 | 07:36 PM
Guru's Avatar
Crower will not have cams available but luckily Brian Crower is working on some which are just about done. Both the all motor and the turbo guys will benefit greatly from these.
Old Sep 1, 2006 | 01:36 AM
release2063's Avatar
what about the s/c guys?
Old Sep 3, 2006 | 05:25 PM
Prototype_xB's Avatar
Word
Old Sep 3, 2006 | 05:57 PM
godslostchild's Avatar
im waiting
Old Sep 5, 2006 | 01:30 AM
HP_Pirate's Avatar
you guys need to do some research before informing people of your misled beliefs of cams and there effects of only changing rpm range. thats rediculous.
your giving people false info and is causing alot of people who don't know alot to do stupid things or just ignor whats important.
gmoneys friend is right on the money. you can change duration, lift, advance, retard, ect. these may not increase power but will change low-end mid-range and high-end power points. extemely important to FI guys. and more lift means more air and fuel, longer duration means more and fuel. more and fuel means more power, provided the two are balanced. you need to do some research on wich cam will work for you before you just buy one. even though none are available. I recomend seeing what everyone is going to put out and how other scion owners like certain cams and then decide what will work best for your application.
just my .02
Old Sep 5, 2006 | 11:44 PM
HP_Pirate's Avatar
sorry mis typed.
more AIR AND FUEL means more power.
steeze69
May 24, 2021 02:57 AM
Ways808
Aug 2, 2015 08:13 PM
eric_m
79
Mar 17, 2013 12:21 AM
kshymkiw
26
Nov 5, 2009 09:14 PM
vintage42
Feb 3, 2007 05:06 PM
