Can i get some insight??
Old Feb 15, 2008 | 06:24 PM
teardrop9696's Avatar
Default Can i get some insight??
Quick question.....i was driving the other day when some focus revved it up next to me.....me being the way i am, lol , i revved up 3 times....i got to the place i had to go....about 30 min later i started my car back up and realized that my check engine light came on....and the last time that came on was when i installed my headers without the antifouler.....needless to say....it stayed on for about 1 full day.....the next day driving to lunch....the light just shut off...which led to me believe that it was probably just my o2 sensor acting up.....does anyone else have any ideas or has this happened to anyone else? i'm not too worried about it.....when it happened i was but now im banking on the "it was the 02 sensor" lol comments???!?!!! lol
Old Feb 15, 2008 | 07:39 PM
SengTC3's Avatar
could be gas cap =D
Old Feb 15, 2008 | 11:03 PM
two0sickness's Avatar
My check engine light came on right after I installed my header too, but since I work at a dealership I had to hook up my car to the techstream (scan tool) and manualy clear the codes. So my suggestion is that you should take it to Toyota ($100) or some independent shops do it to for cheaper. That should take care of your problem with your check engine light.
Old Feb 16, 2008 | 01:04 AM
engifineer's Avatar
You can clear the codes for free. Just disconnect the battery cable for a few minutes. No need to pay 100 for it. Or you can buy a code reader that will clear them for about 40 bucks. If you mod your car, you should at least have a code reader. You can buy a diagnostics tool that will actually give you sensor data, that plugs into a laptop for 200 or less if you look around, or just get a scangauge.
But if you are running a header without an antifouler , it will eventually come back on. Some people have it come on right away, some say it is intermittent. But without an antifouler, it is going to cause issues with that.
Clearing codes does not keep them from coming back. It just resets it until the issue comes back, or is present for enough "trips" to set the particular code
But in any case, without reading the code and telling us what it is, we will have no idea what it is trying to tell you.
Old Feb 17, 2008 | 09:40 PM
well thats the thing...i have the antifouler....so when it came on...i was liek wtf....and i thought it was something serious...... but then the next day...it just went away liek nothing....... it was ____ing weird.....o well- whatever lol thanks anyways
Old Feb 18, 2008 | 12:18 AM
engifineer's Avatar
It seems that the antifouler trick is not always 100% effective, so it may just be that it is an intermittent thing with that. To be sure, just get the code pulled next time.
kfisher8
Aug 14, 2015 03:21 PM
BBesco2021
Scion tC 2G ICE & Interior
Aug 13, 2015 03:23 AM
TheRealShark
Aug 5, 2015 05:08 PM
roadrunnergt
Jul 20, 2015 05:25 AM
Mjdavis1994
Jul 18, 2015 04:29 AM
