cel once again......
i have this tsudo header for about 8months now. i love the header and i bought from speedelement. when i got this header it came with a 90 degree antifouler. since i got it i never had any cel problems. i only get the cel when i go more than 60 mph on the freeway. when this cel goes on i just do the reset thing with the battery. back then i don't really drive so much in the freeway but with the job location it's mostly freeways now.
anybody have this issue with the 90degree antifouler. i don't want to reset the ecu everyday. any inputs guys and gals r very welcome. thanks..........
i can just ignored it like u said, i just wanted the cel not to come on again and again u know what i mean. i want a header mod done right. i was aware that a 90degree antifouler will resolves this issues. is there anything else i could do with this thing???
Yeah i see what you are saying. Im not sure what else can be done. I thought I heard something about some kind of washer mod but dont quote me on that. Maybe try a search and see what pops up.
i did try searching before posting. i know about the spark plugs trick. do u think its something else other than the header issue. anybody had similar problem not necessary with tsudo brand? any header. no cel when driving under 60mph/cel is on when driving over 60mph. weird......
Check your PCV valve.......could be loose.....check the gasket,could be gettign air into the pipe and causing cel,check welds,could have a broken one,check airfilter,check defouler and make sure it is tight.
thanks. I'll do it this weekend until then I have to just reset the ecu everyday... Question for socal peeps. Does anyone have a scangauge and a free time to help me read the code??? I called autozone they don't do the free scan anymore.. The scan should take no more than 10mins. Please..... anyone I'm located in Anaheim buena park area..
a anti fouler will fit on the L fouler.jsut barely,but my guess is it might be loose or even the PCV on the valve cover is loose.....once you get the code it will narrow it down,but our buddy had a lose PCV valve and it threw the bad cat cel everyone gets and after taking his exhaust 10 times just happened to notic eit was loose,tightend and it worked good as new.
it is ok to let the cel run a few days.......if it is the fouler,it wont hurt anything.
thanks alot. I'm just waiting for the socal peeps for a favor. I'm on tanabe df210 springs and its pretty low. Enable for me to look under I have to jack it up. I'm going to check everything I can check for now.
the answer to that is no. When I installed my header the cel came on. The antifouler wasn't installed at this time. The next day I came back for the antifouler that I was promised to get. When I installed it I reseted the ecu and the cel was gone. I noticed the cel came on after about 1 week and 100 miles on the freeway. I reset the ecu again . The cel was of. Like I said before I hardly go on the freeway. On the side street there r times I will go past. 60 mph this is no traffic not racing. A quick 60 mph drive. About a month later I drove on the freeway and going past 60mph cel comes on. In my mind its the antifouler not doing its job on high speeds. But under 60 side street no problem. I never got the cel read due to the fact it only goes on the freeway.
xb4lf
Apr 4, 2015 07:15 PM
