CLUTCH BLEW! PIC UPDATE PG5!
Old Mar 19, 2009 | 03:31 AM
1989menace's Avatar
Default CLUTCH BLEW! PIC UPDATE PG5!
i was just getting off work and i heard a strange noise. my gears won't go in! i know its my clutch because couple days ago my gears wont go in at all! plus i smelled the clutch burning. so now im thinking about buying a performance clutch. i need some one to help asap! any advice? clutchmasters? act? PLESE HELP!
Old Mar 19, 2009 | 03:39 AM
draxcaliber's Avatar
go to dezod, order a clutch, i have a clutchmaster stage 3, but i think he sells ACT and competition clutch
Old Mar 19, 2009 | 03:42 AM
SquallLHeart's Avatar
i don't understand..
what do you want help in?
we can't really replace your clutch over the internet here..
Old Mar 19, 2009 | 03:49 AM
1989menace's Avatar
THANX FOR THE ADVICE DRAX
Old Mar 19, 2009 | 03:50 AM
also, you have a 2008 tC, how did you blow your clutch already? you don't have enough power to do that looking at your profile, either you've been doing something you shouldn't be doing with your car, or you just fail at driving stick.
Old Mar 19, 2009 | 03:53 AM
1989menace's Avatar
LOL.....all im going to say is never teach someone to drive stick on your car. (my girlfriend) you said stage 3. is that the same as the clutchmasters fx300?
Old Mar 19, 2009 | 03:56 AM
engifineer's Avatar
Unless you are boosted there is no reason for a performance clutch on this car. As drax is saying the clutch should not be going on you.
Also, when you say it is not going into gear, that does not necesarilly mean the clutch is out. If the clutch was completely toasted, it would still be easy to put into gear since a burnt clutch engages less, not more. And with a burned clutch pressing the pedal down still disengages the clutch.
So what happens when you try to put it in gear? Does it grind? If so that shows that the clutch is not disengaging like it should (clutch cylinder, linkage, etc could be at fault). Does the shifter just not move into gear? If so, that could be anything from linkage to shifter assembly to tranny issues. IF this is the case it probably wont go into gear even with the car turned off.
kanundrum's Avatar
i have a Brand New competition clutch stage 2 for sale and I am right down the street from rockville in Laurel
Old Mar 19, 2009 | 03:57 AM
stevejohns29's Avatar
i taught my girlfriend ot drive my car.. she does great in it.. never grinds and has only stalled like twice haha . . not bad since i have a exedy clutch
Old Mar 19, 2009 | 03:58 AM
well, i bought mine with the intent of turbocharging my car, so if you don't plan on doing that, then you don't need a stage 3 clutch, just get a competition clutch stage 1 or 2 from dezod or whatever stage you need if you know your approximate WHP goals.
also, it is a good time to add a few little knick knacks like a stainless steel clutchline, and a light weight flywheel.
http://www.dezod.com/cat_clutches.cfm
http://www.dezod.com/cat-clutch-lines.cfm
http://www.dezod.com/cat_flywheels2.cfm
Old Mar 19, 2009 | 04:00 AM
1989menace's Avatar
engifineer. either way i still have to replace a clutch! so why purchase a oem clutch? i should just purchase a performance clutch and get it out the way rite? and i will be going turbo most likely end of this year
yeah, i taught my ex-gf how to drive stick on my car before i put in a new clutch, flywheel, and LSD, cuz i figured any damage she could do would be undone by all those anyway.
when she wanted to learn more after that, i taught her on my brothers old isuzu rodeo sport, which is what i learned on.
Old Mar 19, 2009 | 04:01 AM
engifineer's Avatar
I dont think you read my whole post. If you cant get the car into gear, that does not mean your clutch is the problem.
If the clutch is burning, then yes it needs replacing.. then you can still figure out why you cant get your car into gear.
1989menace's Avatar
draxcaliber. ur a luck dude. the good news is my girlfriends paying for it! yay! lol
Old Mar 19, 2009 | 04:02 AM
rosedaleny806's Avatar
wat year is ur car man? my car is and 05 with 80k on stock clutch and its still great and I taught my girl to drive aswell too
Old Mar 19, 2009 | 04:04 AM
curtislo9's Avatar
1989menace....you really don't want to solve your problem do you. Answer engifineer's freaking questions if you want an answer..
Old Mar 19, 2009 | 04:05 AM
1989menace's Avatar
engifineer. i had to tow my car to my house just an hour ago becase MY GEARS DONT GO IN AT ALL! what do u think i shuld do?
well, since there hasn't been anything done to your car that could caused this problem, why not just take it to a dealership?
your in gaithersburg, take it to fitzgerald toyota service, they're good people over there.
Old Mar 19, 2009 | 04:06 AM
engifineer's Avatar
Are you saying that the shifter doesnt click into gear? (that is what dont go in at all would mean).
Or are you saying that the shifter will click into gear, but when you release the clutch the car does not move? That would (most times) mean your tranny goes into gear just fine, but the clutch is not engaging.
Those are two different issues.
Old Mar 19, 2009 | 04:09 AM
1989menace's Avatar
draxcaliber. HELL NO! they find every way to bs you and not cover it under warranty. there gonna look at my engine bay and know its not stock. i just hope its the clutch
