Clutch Grinding
Old Jul 11, 2007 | 03:10 PM
05FMXtC's Avatar
Default Clutch Grinding
Just recently, whenever i slam 2nd gear i get a grind. i know its not me just messin up the shift. its kinda a small grind but i no somethin isnt right ..every other gear is fine and under normal driving 2nd gear is also fine, its only when i get on it and shift at a high rpm....anyone got any advice...hope my clutch isnt goin....
Old Jul 11, 2007 | 04:22 PM
Scott8's Avatar
learn how to shift better.
It sounds like you are mis-shifting since you are "slamming" it into gear.
Old Jul 11, 2007 | 06:37 PM
giftednimrod's Avatar
I have trouble puttin it in reverse from time to time and itll grind a little
Old Jul 11, 2007 | 06:39 PM
equinox2355's Avatar
Are you running MT-90? A lot of people have either had it lessen or completely disappear when using MT-90 in their transmissions.
How many miles on your car?
How many miles on your clutch?
Old Jul 11, 2007 | 10:47 PM
05FMXtC's Avatar
i'm not mishifting, i know how to shift just fine...im not slamming 2nd...i was just trying to emphasize a quick shift as if i was racing....
i got just about 30k miles on the clutch
Old Jul 11, 2007 | 10:51 PM
Scott8's Avatar
30K is way to soon for a clutch to wear out, unless you are driving it like it's stolen
Old Jul 11, 2007 | 11:59 PM
hPower's Avatar
Check your tranny fluid level and make sure everything is working properly. This, and the reverse issue, could be a sign of synchros in the tranny getting weaker.
Old Jul 12, 2007 | 03:21 AM
malibuboy54's Avatar
sounds like you are either popping the clutch, and not getting through the gate all the way before letting the clutch out......don't think there would be a clutch problem, especially with your limited power mods.....do you have a short shifter? i know some companies have had issues from 1 to 2.....for the reverse problem, NEVER force the shifter through the gate if the syncros are not letting it in.....usually if i cant get in reverse, i temp shift into 1st, and then go to reverse, usually does the trick....this tranny and clutch is pretty damn leniant on driving, and never have heard anyone have problems with 2nd gear unless you have a short shifter.....just sounds like you need to practice shifting....
Old Jul 15, 2007 | 12:52 AM
Djicey702's Avatar
I am personally aware of this problem and I do believe that you know how to shift just fine. What you are experiencing sounds a lot like (worn motor mounts). When you are shifting into second there is a lot of engine movement and with engine movement nobody should expect smooth shifting, especially on a Tc.
pm me if you have some questions,
I've got a few things I am planning to do about that.
a23r
Feb 1, 2016 04:05 AM
carbinefreak
Sep 24, 2015 02:06 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
BlingSlade
Sep 5, 2015 08:52 AM
scionsux
Sep 2, 2015 05:30 AM
