CreativeCompacts.Com S-Pipe Upgrade Information
Be advised...we are unable to provide sound clips on a stock exhaust!!! We are making the S-pipe to go with exhaust kits... Our company car as well as all our test cars are running our full exhaust kit, so we have no means of getting a sound clip on a stock setup
James
James
The cat is on the header, so if you replace your header with the DC Sports or Alphawerks header you will eliminate the cat.
There is a 2nd cat (resonator) on the midpipe that you could get rid of but it isn't recommended since there are reports it sounds like ___.
Incorrect....
Your stock exhaust has the following
PreCat - Located on your Exhaust manifold aka Header
S-pipe
Second Cat (This is your MAIN CAT)
Resonator
Muffler
Thanks
James
S-pipe
Resonator
Muffler
Thanks
James
Just a couple questions, wouldn't the main cat have all the sensors instead of the precat. Where's the resonator if the 2nd cat isn't it?
Nevermind, I found out the 1st smaller canister on the mid-pipe is the cat and the 2nd larger canister on the mid-pipe is the resonator. Still doesn't explain why if it's the main cat, why it doesn't have any sensors. The OBDII doesn't even know it's there.
A little more info:
The second one is just for the ULEV spec.
An exhaust manifold with an integrated TWC (Three-Way Catalytic converter) is used for warm-up of
the TWC and for weight reduction.
An ultra thin-wall, high-density ceramic type TWC is used. This shortens the warm-up time of the TWC
and improves the efficiency of the exhaust emission purification.
To comply with the ULEV exhaust emission regulations, an under floor TWC is used.
Im knew at the whole customizing thing, so my question is, what exactly is the s pipe that CC is working on, will the s pips just replace whatever is before the axle back?I alreadu have the trd axle back just want to know what i will need to buy or get rid of. sry if it sound like a dumb question guys, bear with me.
Originally Posted by hotbigd
Im no mechanic, how hard would it be to put on DC headers, and a new S pipe(If and when available), and an injen exhaust?
Thanks for the info... but can you be more specific. HKS headers? How much cause i can DC sports for 240$. What about intake? I want an Injen, but i cant find if they make one... Im looking at an injen exhuast ? good bad any thoughts?
Giravani means the HKS axle-back exhaust, not header. Currently Injen does not make an intake specifically for the tC but the short ram Injen from the 2.4L Camry works. Either go DC Sports or if you can afford it, Alphawerks for your header.
Two questions that I am interested in for the S-pipe...
1. What are you going to do about the compression spring? You have to keep flex in the pipe which is what those springs are for correct...
2. What diameter are you going to make the s-pipe?
