Electrical problem
Electrical problem
So.. i just got my tc back from the dealership. They replace the front axle under warrenty. The car was fine for about 3 days. Today i went out and started it and my battery, ABS, and brake light at on.. Any ideas?
its common after replacing the axles, all those are on because of the abs. disconnect the battery to reset the light, if it comes back on again then the abs gear on the axle is most likely damaged. just reset the light and see if it comes back if you dont wanna drive back there for them to reset it
that was the first thing i did was disconnect the battery , they were still on, but i took out both ABS fuses and it turned off all three lights. I started the car and its fine now. Thanks
