exhaust problem
Old Aug 5, 2008 | 05:53 AM
joeya28's Avatar
Default exhaust problem
so my exhaust is. alphaworks header, megan s, megan mid, hks axle back
something isn't hanging right and it vibrates, im not sure why. two things, if i wanted to put something on it between the pipe and the metal what would you suggest? and two anyone have pictures of the HKS hanger that you have to put on because this didn't happen with my trd im thinking i messed up that hanger.
Old Aug 5, 2008 | 08:00 AM
joeya28's Avatar
no? i was thinking radiator hose, pipe insulation or maybe some heat wrap then a radiator hose over it.. idk this is a headache though
Old Aug 5, 2008 | 05:21 PM
tCtCtC's Avatar
theres a bolt on the heatshield for the mid pipe. with my tsudo, it rattled so much. to the point it was louder than my bov.
check that
Old Aug 5, 2008 | 06:56 PM
crush02342002's Avatar
ive used high temp red rtv in between my exhaust pipe and the rear suspension, but only use it if the rattle is towards the rear of the car. all you gata do is unhook a few of your hangers till the exhaust hangs lower and apply a generous amount of rtv where it hits and let sit for a couple of hours.
Old Aug 5, 2008 | 07:09 PM
joeya28's Avatar
check that
your both right i found two places where it did it. one was the heat plate on the mid pipe... did you remove the plate?
and the seconds on the resuspension in the back whats rtv?
Old Aug 5, 2008 | 07:12 PM
aka gasket maker
aka silicone
aka sealent
lotsa people call it different
Old Aug 5, 2008 | 08:19 PM
joeya28's Avatar
ight thanks man... high temp silicone
Old Aug 5, 2008 | 08:25 PM
you got it mang
Old Aug 5, 2008 | 09:35 PM
tCtCtC's Avatar
well... i just melted the freakin bolt. well, I didnt, my mechanic did. but now if you want to get the heat shield off for some reason, you have to chop it off
carid
Feb 9, 2015 01:49 PM
xxmanrd92xx
11
Feb 4, 2015 01:40 AM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
hotroddelux
Dec 3, 2014 11:33 PM
