A/F Ratios
Alright, I am running an Injen CAI and a full header back exhaust with no cats. The car seems to idle at 14.7 and casually drive between 14.8 and 15.1. At WOT it richens up to around a 12.9-13.2. I was told that is actually a bit lean for WOT and wanted to get some opinions before I spray it, hopefully some time this week if things go well.
Also, would an EGT gauge be recommended for a 50 or 75 shot? I know that a sudden drop in EGT represents detonation, but would it be likely on a shot that small?
For boost, yes, too lean. For all motor your right were you need to be. With a wet shot it should be ok, just make sure you continually monitor. your idle and regualr driving is perfect.
You dont need an EGT gauge.
EGT gauge can not really measure detonation although never a bad idea just to be on the safe side. To do it properly you need a way to see the voltage on the knock sensor and log it or of course a good ear. Even a good ear can sometimes not hear faint detonation so I prefer to log the knock sensor data for tuning purposes.
BlingSlade
Oct 19, 2016 12:39 AM
SupaWhiteTc
Mar 15, 2005 11:25 PM
