Greddy E-Manage Ultimate and an N/A Engine
Old May 8, 2009 | 07:30 PM
youngflyer's Avatar
those are pretty darn good numbers but it still makes me sick to my stomach thinking the 08 hondas can put down over 250 all motor without pistons
Old May 8, 2009 | 07:43 PM
Thorium06's Avatar
yeah at 900000000rpms
Old May 8, 2009 | 08:19 PM
NYNATIV's Avatar
Originally Posted by BlckdOutTC
get off that 93 octane
Who said I was on 93 octane?
Old May 8, 2009 | 09:11 PM
BlckdOutTC's Avatar
Originally Posted by NYNATIV
I was getting a little over 25 MPG before the tune (93 octane).
you did
Old May 9, 2009 | 02:27 AM
speedy000's Avatar
Very nice! Would gains be same with emanage blue
Old May 9, 2009 | 03:26 AM
NYNATIV's Avatar
you did
Haha... my bad. It's the old age. I switched back to regular because of the posts I read plus the prices have been going up.
Old May 9, 2009 | 03:32 AM
NYNATIV's Avatar
I don't think so because you are more limited to what you can do with the Blue. At least that's what Giles told me. But Giles could answer that one for you. The only way would be to get some Dyno numbers on it.
Old May 9, 2009 | 04:10 AM
speedy000's Avatar
does this hurt the car in anyway!? It's my dd so I'm scared to mess it up
Old May 9, 2009 | 12:38 PM
NYNATIV's Avatar
It shouldn't hurt it in any way. If anything, it's helping it because you're adjusting the air fuel ratio so that you get better performance. If you are barely pushing the pedal down, (about 30% throttle), the car is going to drive economical. If you press the pedal past that, then it's going to give you that extra power. That's all part of the tuning that Giles did. This car is my daily drive too.
Old May 13, 2009 | 06:03 PM
caveman's Avatar
1UP Crew
This may sound silly but I had this question come up and since I have not studying tuning yet this may be the best thread to ask in...
So you tuned solely with the unit and PnP harness right? Since you were tuning N/A you didnt have to use a pressure sensor like everyone needs on boost?
Old May 13, 2009 | 06:06 PM
Thorium06's Avatar
i have dyno numbers with an emanage blue na setup, however they are at altitude and not all that impressive lol
Old May 13, 2009 | 06:22 PM
NYNATIV's Avatar
It's not a silly question. Here's the response from Giles, the guy who did the tuning..
"Pressure sensor not needed.... some modifications (that cannot be published) were made to the plug’n’play harness to achieve our desired goals ..."
Hope that helps.
Old May 13, 2009 | 10:29 PM
caveman's Avatar
1UP Crew
Thanks for the info
Nice numbers you made too!, had to sell all my boost parts so my new project is to keep it n/a and hopefully make some good numbers as well....
Old May 13, 2009 | 10:40 PM
AcidDrop's Avatar
nice numbers with i/h/e, have you looked into changing the 3 pulleys and intake manifold as well? do you think the AEM fic will be able to do the same if not more or less? again nice numbers you posted and now i'm gonna look into tuning my car as well.
Old May 14, 2009 | 02:22 PM
NYNATIV's Avatar
At this point, I don't know what the next step will be. I've been thinking about the pulleys but not sure how much more HP I'm going to get with them. I haven't looked at the intake manifold at all. I need to start doing some research on both and see which way I want to go. I don't even know how much each of the 2 is going to run me.
Old May 14, 2009 | 03:01 PM
stillettoDSM's Avatar
Consider those Crower Cams at all?
Old May 14, 2009 | 03:46 PM
speedy000's Avatar
Pulleys r cheap that manifold is 600$
Pulley set is 200 or so n pulleys make about 7hp on stock cars.
Old May 14, 2009 | 03:51 PM
So if Pulleys make around 7, and the Crower Cams are said to make 15-18, he can break the 200whp hopefully.
ecko04's Avatar
Good gains. I plan on getting my N/A dyno'd sometime next week.
I just ordered the NST pulley set from WeSellCarParts....$250 and the underdrive belt from NST directly. Hopefully, i'll get those in before I take it to be dyno'd.
I also just got the Greddy e-Manage Ultimate....I haven't gotten the tC harness yet though, i'll get in contact with Greddy, I think they have them on their website for $230.
That manifold is a pretty penny and it isn't a direct swap, what i've been told is that it takes some degree of modification to get it to fit correctly.
Plus I would rather keep the stock plastic manifold for my setup.
Old May 14, 2009 | 03:56 PM
ecko04's Avatar
Those numbers are pure estimates and the type of dyno and measures used to estimate hp gains varies drastically. If he were to put his car on a DynoJet it would dyno at 200whp, but that's because of the type of dyno, there are a lot of factors. tCpete has a fully built motor N/A motor and last I checked, don't quote me on this, still hadn't cracked 200whp. Surely, the cams and raising the rev limiter would help but changing the cams is a PITA and not a 'oh I have 3 hours to spare' type of task.
