having problems holding idle!!!!
Did you mess with the MAF sensor or either of the two rubber vacuum lines that go from the valve cover to the intake mani or intake piping? I know when I did something wrong on both of those it would crank up the motor but it would shut it back down almost instanteously.
What caused your vacuum leak? It may lead you to what is causing the idle issue. What all did you do to it/mess with when you did the full exhaust? That may help out some people that are trying to figure it out.
Ok, so I'm taking it that you have a CAI. Did you make sure your maf sensor is plugged in fully. When my wasn't plugged in it bogged the engine down so it wouldn't go past like 3.5 or 4kish I think.
CapnChunk
04-13-2015 04:06 PM
cid_mcdp
01-05-2015 02:45 PM
