Help!!! Bolt going in circles
Old Jul 29, 2010 | 11:25 PM
KeithMac115's Avatar
Default Help!!! Bolt going in circles
Ok so I put headers on my car. It was fairly easy. Everything came out fine but the top right bolt is on but won't tighten or even lossen now. There's a small leak but the car still runs fine. Any idea how I can fix this?
Old Jul 30, 2010 | 01:09 AM
Murphys_Law's Avatar
sounds like you rounded if off in the block? did you use a torque wrench to install it
Old Jul 30, 2010 | 01:23 AM
KillaSpiceTSW's Avatar
You can try cutting the head off and pull the remaining bolt out with pliers. Just a thought. Do it at your own risk of course lol
Old Jul 30, 2010 | 02:52 AM
Eziekel's Avatar
so, basically you stripped the bolt?
Old Jul 30, 2010 | 05:31 AM
TcPrincess's Avatar
its stripped. use a flat head to pry it out while turning it. you might have to use a over sized bolt or you can find someone to timesert it so you can use a stock bolt (i would do this).
GL
Old Jul 30, 2010 | 05:21 PM
^x2 and have it rethreaded, take it somewhere for this if you arent comfortable doing it
Old Jul 30, 2010 | 07:07 PM
Yes I used a torque wrench but it never got tight. Once it went where it is now it just stayed. I don't know if I stripped the stud threads or the bolt threads. The outside of the bolt is fine. I tried the screw driver thing and there just isn't enough room to get it between them. I was thinking to just tr and remove the stud but I'd need the torque bit tool for it.
Old Aug 1, 2010 | 05:25 AM
TcPrincess's Avatar
i forgot that it uses studs, not bolts. you got extremely lucky, its very easy to replace a stud/nut. if you can, grab the end of the stud with vice grips or a bolt extractor and remove/replace.
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
crimson_sinn
Sep 25, 2015 09:41 PM
