help! remove ecu
Old Dec 2, 2009 | 08:50 PM
GammaTNT's Avatar
Default help! remove ecu
help, i will be uninstalling the S/C soon by ptuning soon, i need number on the ecu.
How do i remove the ecu?
any tip would be helpful. thank you
Old Dec 2, 2009 | 10:31 PM
cmcpride's Avatar
Default ecm
what number, part number. auto or manual trans ?
Old Dec 2, 2009 | 10:33 PM
GammaTNT's Avatar
ptuning want me to fax the number printed on the ECU to them.
Old Dec 2, 2009 | 10:37 PM
cmcpride's Avatar
are the going to replace and install a new or used ecm. are the chargeing you extra. auto or manual transmission?
Old Dec 2, 2009 | 10:43 PM
cmcpride's Avatar
if you remove your glove box you should be able to see label. all youll need to remove ecm are 10mm socket and extension with ratchet.
Old Dec 2, 2009 | 10:44 PM
GammaTNT's Avatar
they will order a new ecu for me. for 2006 manual transmission,
Thank you for the reply
Old Dec 2, 2009 | 10:49 PM
cmcpride's Avatar
are the chargeing you extra for a new ecu/
Old Dec 2, 2009 | 10:53 PM
GammaTNT's Avatar
they are going to order all new parts from toyota dealer . i forgot to ask my dealership to give me back my old stock parts when they install the s/c. ( I will never make that mistake again)
(i wonder how much i can part out the sc?)
cmcpride's Avatar
how much are they chargeing you if you dont mind me asking.
Old Dec 2, 2009 | 11:03 PM
cmcpride's Avatar
the only parts youll need are air intake hose and air filter case. or just buy a used cold air intake for $50 and just remove s/c . and plug your oil pan drain hole. they sel those for $5 bucks. and install your oem belt . dam ill even give you mine just pay for shipping.
brett561tc
Sep 15, 2015 06:33 AM
Bmfxtreme
Aug 18, 2015 01:25 AM
Tak16
Jul 7, 2015 05:45 PM
shatterfoxy
May 8, 2015 03:59 AM
kdanie
47
Feb 7, 2006 05:46 AM
