Hesitation and intakes.
I am currently using the weapon r intake and notice a bit of hesitation the most noticeable gear is second. I was talking with a guy today who said that my car might be running a little lean. Could installing a computer correct the hesitation problem or is there anything else i should be looking into?
I dont know sounds like the guy wanted you to break him off more cash.
dude,
if you just reset you car you should be cool!
disconnect the battery for 10 min.
after conecting battery reset your windows and sunroof, and let your car idle for 10 min so your car get used to the more flow of air .
hope that helps.
i also heard some where in a forunm that the Wepon R intake sucks good air but that it still lets in small particals in your ingine (scary) thats what i heard? just a thought.
GOT SCIONLIFE?
All intakes make horsepower by slightly leaning out your A/F mixture. If your car is just slightly hesitant, then that's pretty normal. If it's exessive, make sure your MAF is seated properly. The hole for the MAF on my Weapon R intake was just a bit too big. I fixed it by using a slightly bigger rubber o-ring.
GOT SCIONLIFE?
dont worry, after driving with it for a week it will stop.....
everytime i reset my ECU my car doesnt drive as smooth as if i have been driven it for a week. after a few days i think the car will get use to the intake and adapt its new aftermarket part
i think the hesitation is gone. i haven't had a chance to get on a road where i can run through the rpm's especially since it's been raining around here. It was one of two things that fixed the hesitation.
1. i was using a pcv hose for the intake nipple that connects to the engine. when i took it off it looked like part of the inside of the hose had melted next to both of the connections which was blocking some of the air flow.
the weapon-r directions don't tell you, but when i talked to creative compacts they said that the new weapon-r design uses the stock hose. So i put the stock hose back on.
2. I checked all the connections and reset the computer.
Well, I just removed my Weapon-R Secret Weapon from my TC. I kept encountering the same problem, terrible hesitation and loss of bottom end power at low RPM's. I tried four times to reset the ECU, let the car idle for 10 minutes before driving it and then I wouldn't even drive it hard for at least 50 miles. Right after the 50 miles it works great and feels frisky at low RPM's, but after roughly 300-350 miles it seemed like the ECU would detune the engine or something. I could barely take off in 2nd gear without bringing up the RPM's higher than usual(2800). Normally with the stock intake it's no problem to take off in 2nd easily.
It's crying shame too because at 4000 RPM's that intake really comes alive. But in my daily driving I don't get up that high unless I'm feeling cocky and want to get on it.
I don't know what to do at this point but I know your pain..
Team No Limitz
You guys do know that an intake will slow you down a lot in the lower end RPM's right?? I bet you if you raced a stock tC in the quarter mile w/ your tC w/ only an intake that the stock tC will win. The thing with intakes is that what you lose in the low end, you will gain in the mid to top end.
i don't know. my car seems like it pretty much has more go all around with the intake than without it. if this hesitation comes back i will switch back to stock or i will try the injen intake that i have sitting around.
Dude you have an injen intake sitting around and you are not using it ?
Injen has way better system i feel too many hesistation stories with weapon r.
Originally Posted by jmiller20874
A piggy-back for just an intake, that's just rediculous. Reset the ECU, let the thing idle for about 15 minutes and try again.
since i have trouble shot the weapon r i have not had any problems with hesitation. and find that now... it runs better than the injen intake. i am going to keep the injen around a little longer but will sell it soon if the weapon r continues to work as well as it has been.
ok dude! go for it !
mc1114
Aug 12, 2015 02:07 AM
Atticus_the_XB
Apr 13, 2015 06:46 PM
2005, acceleration, air, flow, hesitates, hesitating, hesitation, intake, light, mass, problem, scion, sensor, sienna, toyota, transmission, weapon, xa, xb
